Big HP guys. What's your exhaust setup?
Old May 31, 2006 | 11:21 AM
  #31
NJLT1SS's Avatar
Re: Big HP guys. What's your exhaust setup?
BADST95, from the headers to tailpipe, whats your exhaust setup?
Nick
Old May 31, 2006 | 11:31 AM
  #32
BADST95's Avatar
Talking Re: Big HP guys. What's your exhaust setup?
Originally Posted by engineermike
Check this one out:
http://www.magnaflow.com/02product/s...ne=main&id=491
$136 from Summit.
It's a straight-through design also + stainless steel.
Mike
However, if this muffler could fit under the car, then two tail pipes could be run, but I would venture to say that it's too big to fit.
Old May 31, 2006 | 11:44 AM
  #33
BADST95's Avatar
Smile Re: Big HP guys. What's your exhaust setup?
Nick
FLP prototype 1 3/4 inch long tube headers, custom fabricated 3 inch 4 inch y-pipe (no cats) by FLP, Mufflex 4 inch intermediate pipe, Spintech muffler (4 inch inlet, dual 3 inch outlets).
Video clip...
http://v8havoc.com/stuff/mitch/blownbird.wmv
Old May 31, 2006 | 12:31 PM
  #34
NJLT1SS's Avatar
Thanks for the pics BADST95. I run something very similar on my car, except I use the Flowmaster on my 4 inch Mufflex. Just a little FYI, Fred (Injuneer) has posted this several times about George Baxter's 30th. When his car was making 1125 HP or so, George ran 1 3/4 long tubes, 3 inch y to a 4 inch Mufflex with a Flowmaster muffler. He removed the Mufflex setup, and installed bullets with turndowns right onto the collectors, and redynoed, and showed no difference in HP. Im personally not the biggest fan of Flowmaster, I would have chosen a Magnaflow if it was an option. When it comes to Flowmasters, I hear too many conflicting stories of people who switch and report eiher a gain, or loss compared to other brands.
Nick
Old May 31, 2006 | 12:48 PM
  #35
BADST95's Avatar
Nick
Thanks for the info. I tend to believe that a 4 inch cat back is just fine for my set up and don't need to waste my time by changing things. If I have some spare time, maybe I'll change things to see if any increase in power can be made.
Old Jun 2, 2006 | 02:08 PM
  #36
akafred's Avatar
i am thinking of running dual 3" exhaust on my twin turbo camaro.
now I was wondering if i run cats and exhaust all the way to the back with no mufflers how loud will it be?
i am thinking that the turbos must kill some of the exhaust noise?
Old Jun 2, 2006 | 07:41 PM
  #37
boosted-lt1's Avatar
engineermike:
What do you think about this scenario?
Possible a setup requiring more exhaust flow will benefit more so by removing a muffler????
-Scott.
Old Jun 2, 2006 | 08:08 PM
  #38
engineermike's Avatar
Originally Posted by boosted-lt1
engineermike:
The question being, why a Flowmaster muffler kills 30 hp on a 450 hp car and none on an 1125 hp car.
Well, since I wasn't there and can not prove or dis-prove the dyno test, I'll assume that the data given is exactly correct.
Perhaps Baxter's car had a tad too much camshaft overlap. Wasn't he running alot of boost? Like 25+ psi? Well, with a blower car and 25 psi in the intake port plus 0 or negative pressure in the exhaust port, you can easily over-scavenge the chamber and lose air/fuel out the exhaust. Turbo car's have the opposite problem because for 25 psi boost, we might have 40 psi backpressure, but that's a topic for another day.
My point is that perhaps a restrictive muffler helps prevent overscavenging on a high-boost supercharged engine. Removing the restriction allows overscavenging, but also reduces pumping losses. So, the net result is zero.
Mike
Old Jun 3, 2006 | 06:42 PM
  #39
[QUOTE]My point is that perhaps a restrictive muffler helps prevent overscavenging on a high-boost supercharged engine. Removing the restriction allows overscavenging, but also reduces pumping losses.QUOTE]
Sounds more combo specific (complicated). Some cars gain more or less than others depending on breathing characteristics of the setup.
Not saying a Flowmaster is/isn't a poor flowing muffler (I can't comment).
-Scott.
Old Jun 4, 2006 | 06:50 AM
  #40
FASTFATBOY's Avatar
A normally aspirated combo needs MORE exhaust, a power adder combo can always get by with less exhaust....the power adder is helping it get pushed out. The all motor combo is having to do it on its own.
I have seen cars go pretty darn quick with Flowmaster shootout style mufflers, ANY crossflow muffler will flow less than a straight through muffler.
Even back in the early 90's NMCA Pro-Street cars were running low 8 second slips with Flowmaster mufflers(of course they were ALL power adder cars).
Personally I have a normally aspirated combo going together(and have been working on it 3.5 years) We opted for the BIGGEST system we could put on the car, shooting for 500 rwhp normally aspirated through an auto.
Hedman 1 7/8 race headers(modded to work with a/c and power steering)
Home built 3.5 inch Y pipe
4 inch Mufflex
4 inch Magnaflow muffler with single turndown on drivers side.
If that dont get er done we in trouble.
David
Old Jun 4, 2006 | 10:12 AM
  #41
EDS Z28's Avatar
Video clip...
I think I have the same headers as you do, but that's about it. I have to run cats here in CA (dual 2-1/2"). I also had the y-pipe enlarged from the way it came from flp, since it seemed to be too small. Mine is the standard 2.5" to 3" y-pipe. I tried the offroad pipes one time, but will never do it again. It sounds incredible, but too loud. The cats quiet it down a lot. So if your driving on the street with offroad pipes, you may get pulled over. . And if the officer sees no cats on the car, we'll you could be in big trouble. I guess it all depends on the guy who pulls you over, he may just want to see what you have under the hood and doesn't give a rats *** about emissions. I suppose with no cats, a quieter muffler is needed, like a flowmaster 50 series.
Old Jun 4, 2006 | 12:08 PM
  #42
BADST95's Avatar
Wink Re: Big HP guys. What's your exhaust setup?
I have the prototype FLP headers... slightly different than the production headers... easier access to the #5 plug. They changed the design for production reasons. Anyway cats would be a restricion in my application and I have showcar insurance which means an emissions exemption.
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 08:12 PM
MadMav
Feb 6, 2015 11:02 PM
