Best prices you guys have seen for FAST\BIG STUFF 3
Re: Best prices you guys have seen for FAST\BIG STUFF 3
When I talked to White Racing he recommended the BS3 because the box was a sealed box and would be better suited for harsh environment under the hood.
ZBLKHELLRZR: Nice.
I'm going for the stock appearance (aside from the pillar gauges). Though I'll probably talk myself into a cage after the first time I drive it. Going from ~450rwhp to about 700 should be a little incentive.
Here's some links from the www.bigstuff3.com website that show some comparisons with the competition.
http://www.bigstuff3.com/gen3featurecom.pdf -Features
http://www.bigstuff3.com/gen3pricecom.pdf - Price
http://www.bigstuff3.com/proc.pdf - Processors
Yes, but you would need either LTCC, crank trigger, cam driven distributor, or opti adapter(sold by whites racing) to make the ignition work. Since the opti is not an option for me I think the best solution is the LS1 style coil on plug ignition or LTCC
Only if you plan to go to coil on plug ignition.
What do you want to know?
It's an LS1 BS3 on an LT1. I'm running a 24X crank trigger, and the opti has been converted to a cam position sensor. Here's a pic of the converted opti.
The ignition is basically the LS1 truck coils (coil per cylinder).
For good points vs. bad points, I chose the BS3 because I feel it's the best on the market. It has features that none of the others have, and I think it's the best setup for a engine management system that references boost.
