best baby cam for boost?
Old Feb 22, 2010 | 09:03 PM
sn8ke eatr's Avatar
im looking for a cam for a 355 lt1 which will have tame idle but still make good power. ive even considered using a stock lt4 cam with 1.6 roller rockers for a sleeper effect. im dynomating the whole interior and want to be able to cruise like its stock.
whats my best bet? custom cam? im on a budget but dont wanna leave a significant amount of power on the table. this motor will probably also have a small shot of nitrous along with the supercharger. im hoping to push between 9-12lbs of boost.
can someone suggest me a suitable cam? id like it to be new, its going in a new motor
Old Feb 22, 2010 | 09:21 PM
onefastmx5's Avatar
Give Llyod Elliot a buzz... www.elliottsportworks.com. He has a custom one that your describing. I'm getting it next year when I buy LE1 heads.
Old Feb 22, 2010 | 09:31 PM
sn8ke eatr's Avatar
loyds got a great product, im using an old set of heads done by him. by chance, do you know the going rate for a custom cam of his?
Old Feb 22, 2010 | 09:33 PM
reamo04's Avatar
call up bullet cam's
Old Feb 23, 2010 | 07:34 AM
RealQuick's Avatar
I believe LPE has a 211/219 cam... should work well.
Old Feb 23, 2010 | 09:03 AM
jsetzer's Avatar
Stock might be a good option for you.
Turbo? Blower? Gears? Power goals?
A lot of the small cams - I had a 502 - Tend to have mild specs but be on a 112 lsa. Mine still had quite a bit of chop at idle.
Old Feb 23, 2010 | 11:43 AM
jay_rich's Avatar
My cam isnt a baby cam but nothing crazy, Idle is awesome. I found it idled simaler to my Hotcammed 355 I use to have.
230/236 .544/.555 114lsa
Jay
Old Feb 23, 2010 | 12:29 PM
blown94's Avatar
In order to get an appropriate response I think you need to specify power range, not just tame idle and "good power". To some good power might be 400 at the wheels, which with 10-12 psi boost is probably attainable with a stock cam. While on the other hand good power to someone else could mean 600 rwhp. So I wouldnt venture to give you a guess until you give a little more info.
Old Feb 23, 2010 | 01:25 PM
reamo04's Avatar
FWIW, I was going to go with tame idle and about 500RWHP, I had a cam specced for my LSX, it was 216/214 .561/.559 113+2.
Would have been stock like idle, torquey down low, and made good power within stock redline
Old Feb 23, 2010 | 09:49 PM
sn8ke eatr's Avatar
pretty much got it narrowed down to one of the following:
Lingenfelter 74220 Camshaft L98, LT1, LT4 1987 - 1996 TPI - Hydraulic Roller 215/220 .534/.544 HR114
Lingenfelter 74211 Camshaft L98, LT1, LT4 1987 - 1996 TPI - Hydraulic Roller 211/219 .530/.560 HR112
or a factory lt4 cam.
will the 219 cam give me the most power? im told it will idle similar to a hotcam, thats about has lopey as id like, thanks for any help,
Old Feb 23, 2010 | 11:14 PM
94SLUG's Avatar
224 236,501i/516 114lsa idle is tame @ 850, I have never had a person ask what cam is that, more so what blower..
Old Feb 23, 2010 | 11:30 PM
jsetzer's Avatar
I'll let you know how my 230/236 114 goes soon
Old Feb 24, 2010 | 07:42 AM
97WS6SCharged's Avatar
I ran a 224/236 114 LSA in my stock bottom end for years. You could tell it wasn't stock but it was very civil for daily commuting. Idled at 1k rpm, had a nice bump when cold and it smoothed out when it warmed up. I could run 70 in 6th gear at 1600-1700 rpm without a hitch.
The motor is still alive in a friend's 94Z running in the 12's with over 120k miles on it now.
Old Feb 24, 2010 | 12:39 PM
blown94's Avatar
You need to look at the overlap of the valve timing events. Id guess the 114 lsa cam is going to have less overlap and its a tad larger so if thats the case I would think it will make more power and sound more stock at idle as well.
Old Mar 26, 2010 | 12:51 AM
Jameslt1TA's Avatar
Here is the cam card im running in my car. Drivability is good and it seems to make great power. I need to get it on the dyno. It doesnt lobe anything like the 236/24x joe o cam that was in my trans am, but still sounds nice through the open downpipe.
CORE C07-8A CAMSHAFT BLANK, LT1 DUCT SEMI (L.L) Special Grind
GRIND # LT1 3035S /3035S HR115+3
DURATION @ .050 INTAKE 224 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 224 INTAKE 1.60
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3540 EXHAUST 1.60
VALVE LIFT INTAKE .566 LOBE LIFT EXHAUST .3540
VALVE LIFT EXHAUST .566 LOBE SEPARATION 115.0
