The beast is out of its cage ... :)
Project 383 just left the dyno at 525 rwhp @ 6,100 rpm and still heading north at a phenomenal rate ...
Steel Callies crank
-31 cc dish SRP forged pistons
Crane 1.5 non self aligning roller rockers
Comp cams 224/236 114lsa
SVO 42# injectors
Super FMU, makes 58psi of fuel pressure at 8 psi of boost at 6,100 rpm
AFR 190cc heads with 58cc chamber to make 8.9 - 9.0:1 compression ratio.
Oliver connecting rods, 5.7"
ARP head studs and bolts
Splayed 4 bolt main caps
S-trim blower, 3.125"/7" pulleys
Stock computer with LT1 editor, set the injector constant to 47# and the cylinder volume to 47.875 cu in. Set idle speed up to 850 rpm.
Runs good, air/fuel ratio is solid at 12:1
Gotta say thanks to the board for all the help in answering my questions along the way ...
LWM
Steel Callies crank
SVO 42# injectors
LWM
RUENUF
Mar 13, 2016 03:37 PM
