Ati Procharger 2 Core I/C Install...Pics
Old Jan 11, 2006 | 09:02 PM
  #31
sprayedtransam's Avatar
Re: Ati Procharger 2 Core I/C Install...Pics
Yeah that's more than mine were before I did the supercharger
Glad to hear you figured out the problem ...hopefully...
Old Jan 11, 2006 | 10:48 PM
  #32
WinkleTheMoose's Avatar
.65 was what i was told they were stock. So thats what i'm assuming they are.
Old Jan 12, 2006 | 07:44 AM
  #33
ss97dml's Avatar
i'm running 9lbs. and have mine gapped at .30
Old Jan 12, 2006 | 04:37 PM
  #34
bluelt1z28's Avatar
I had a problem with my twin intercooled procharger were the intake hose would collapse under boost causing the car to bog (loose power) at around 5000 rpm at wot. The intake is so tight in the inlet area that the 90 deg. rubber intake hose would collapse causing it to block the air coming into the engine.
Old Jan 12, 2006 | 06:17 PM
  #35
Kevin Blown 95 TA's Avatar
That's an impressive sig. How fast is it?
Old Jan 14, 2006 | 11:16 AM
  #36
Succesful, this thing roars, the old plugs were actually gapped at .60, and we took them down to .35 with the tr6's. And it definantly don't lack power.
Old Jan 14, 2006 | 08:29 PM
  #37
Well now its not detonating or anything, but it has small chug fits, so i'm going to put the injectors(42lb) back in and see what happens.
Old Jan 14, 2006 | 09:25 PM
  #38
1SlowFormula's Avatar
Did you ever hook that MAF sensor up? Are you changing the tune when swapping out the injectors?
You should do both...
BTW, what tune are you running on?
Old Jan 15, 2006 | 12:21 AM
  #39
Yes, MAF is back on, and yes i'm using a tune from Ion/Madz28/madwolf for the tuning.
Old Jan 15, 2006 | 05:03 PM
  #40
blown94's Avatar
Make sure you have the MAF flowing in the correct direction. Sounds stupid but in the midst of doing 5 other things you sometimes overlook the obvious. Ill admit to having done it once myself and car still ran but didn't seem quite right. And you should definitely be running the 42 lb'rs. if thats what your tune was set for. You could be overworking the stockers if its programmed for 42's.
Old Jan 17, 2006 | 12:23 AM
  #41
Well as of now everything is going back to stock, I don't have the time or money to keep trying to figure this supercharger out. Thanks for everyones suggestions, and i hope everyone else out there trying to install these things on your cars are having better luck then me. Thanks. Again.
Old Jan 17, 2006 | 06:02 AM
  #42
It's never been a matter of luck.
Old Jan 17, 2006 | 07:47 AM
  #43
Whatever.
Old Jan 17, 2006 | 03:50 PM
  #44
So are you selling the system?
Old Jan 17, 2006 | 05:37 PM
  #45
Yes. Once i get it off. I'll let you know.
