Anyone run this Pulley on a powerdyne?
I was looking at powedyne's site and they list a 9 psi pulley for the LT-1.
http://www.proficientperformance.com...ode=D10479-270
I bought a new powerdyne on eBay for a good price and thought 6 psi was the limit.
I'm planning on using variable control water/methanol injection for air charge cooling as well as variable MSD boost timing retard so 9 psi should work.
Does anyone have any experience using this pulley on their LT-1?
Not quite sure what thois pulley is. Unless they recently changed, Powerdyne only offerred a 9 PSI SC pulley for the Mustang set-up. However, they do make a 2.70" diameter SC pulley (which is advertised as the 9 PSI pulley for Mustangs) and if you ask they will modify it for use in an F-body application. It does require some machining to fit on the BD-11A for F-body use. Powerdyne doesn't generally like to do this since it may hurt the SC and/or your motor (if its still stock).
That said ... I have been running the 2.70" pulley from Powerdyne (had them machine it while I was out there) for a couple of years now. It does not increase impellor speed enough to add 3 lb. of boost, but it does get you to just under 7 lb. at 6200 RPM and no belt slip. Figure it is worth maybe 15-20 RWHP at best. But then for the price it may be a good deal if you don't have a stock motor (mine has forged rods, pistons, crank).
Powerdyne charged me $75 a couple of years ago so I would talk directly with them before I bought it anywhere to ensure it clears the SC housing in all the right places.
Later ... Larry S.
Later ... Larry S.
Yes this is powedyne's official site.
They charge more for the 2.70 LT-1 pulley than the Mustang.
Wonder what the difference is.
Maybe it's time to send them an email.
I'll post the response when I get it.
Yep ... I just checked their website and they have added the 9 PSI pulley for F-bodies. I believe it has a little bit more machining done on it to clear the head unit.
Now if they will only release the XB-1A head unit for F-bodies things will get better for me.
Later ... Larry S.
Later ... Larry S.
10-31-2016 11:09 AM
cyteone
02-07-2015 06:04 PM
