Any of you running an Aeromotive 340 lph fuel pump?
Old Feb 15, 2014 | 10:05 AM
David94TA's Avatar
If so, what part number and how much do you have to do to make it work? I can't seem to find a direct fit application for our cars.
Old Feb 15, 2014 | 07:05 PM
MEAN LT1's Avatar
Re: Any of you running an Aeromotive 340 lph fuel pump?
Last time I checked which was about three months ago. Called Aeromotive and they haven't built one for F-bodies yet. They have them for GN's but nothing for us yet.
Old Feb 15, 2014 | 10:15 PM
97WS6SCharged's Avatar
The 11142 should fit just fine though you may lose the bucket. It will strap to the hanger without a problem.
Old Feb 16, 2014 | 01:44 PM
David94TA's Avatar
Will it just plug into the stock wiring harness?
Old Feb 20, 2014 | 11:36 PM
It should use the same blade type connector that a walbro or stock pump uses. That said I would look into the Racetronix hotwire kit or some other means of supplying power to the pump as it will draw more current than the stock harness is capable of supplying.
Old Feb 23, 2014 | 03:22 PM
David94TA's Avatar
I've already got a Kenne Bell Boost-a-pump, so that should work shouldn't it?
Old Feb 27, 2014 | 12:36 AM
As long as you have a wire supplying a steady voltage to the pump you should be fine.
Old Apr 8, 2014 | 08:58 PM
siguy's Avatar
I would also recommend racetronix hotwire kit also to get the full potential of the pump
Old Apr 12, 2014 | 09:15 AM
Kevin Blown 95 TA's Avatar
You guys don't have to buy any special wiring kit to get full voltage back at the pump. Just put an automotive relay back there ($5) and use the oem fuel pump wire to turn it on, then run a fat wire back from the alternator and a good ground, too, and you will have all the voltage you need for one or two pumps. Then the only bottleneck will be the crappy connections and little wires that go through the gas tank bulkhead. If you want to get fancy and run two pumps with one triggered by boost or something, then put a second relay and turn it on with a hobbs switch. Use some good inline connectors and then you can switch the pumps around once if one fails or you want to give the main pump a rest.
Old Apr 14, 2014 | 10:05 PM
DirtyDaveW's Avatar
I have one for our cars but I'm not at the house at the moment. I'll look it up when I get home.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
