air filter splash guard ???
Old Jun 2, 2004 | 04:38 AM
bowtiepwr's Avatar
Question air filter splash guard ???
>when you install the splash guard around the filter (Vortech in this case) ... does it go on top to prevent water from falling on top or does it cover the bottom to prevent splashing water from the road ?
Old Jun 2, 2004 | 08:15 AM
stealth2's Avatar
Is there a picture of it?
Old Jun 3, 2004 | 11:40 PM
OBE1 95Z28's Avatar
On top.
Old Jun 4, 2004 | 04:31 AM
bowtiepwr's Avatar
>I have a pic of it ,but can't host them anymore
I put it under the filter instead of on top to prevent the water from hitting it from the ground .
Old Jun 4, 2004 | 04:41 AM
97WS6SCharged's Avatar
Shouldn't really matter, the little bit of water that actually gets past the filter will usually just get caught in the intake tubing.
Old Jun 4, 2004 | 09:47 AM
Camaro_SS/R's Avatar
I dont think it matter, but I think Vortech has it on top since the car has the splash guard on the bottom already. It sounds like you took out the bottom splash guard from the car though.
Again I don't think it matter, but I left the Vortech guard out to give it move breathing area and routed air from a ducting from the air dam to the air filter. http://f1.pg.photos.yahoo.com/ph/hug...0025+front.jpg
Old Jun 4, 2004 | 04:36 PM
Ultra_Dog's Avatar
Wrong!
My air filter is only a few inches off the ground and I cannot drive in the rain due to splash. When the filter is wet, water will get sucked through and end up dribbling into the MAF, causing instantaneous and momentary loss of signal from the MAF, resulting in a complete drop in engine power.
I really want a better solution, but there just isn't any available airspace in the front of our cars.
Old Jun 5, 2004 | 03:54 AM
bowtiepwr's Avatar
Originally posted by Ultra_Dog
Wrong!
>so where did you install your splash shield ... top or bottom ?
Old Jun 5, 2004 | 04:12 PM
96 WS6's Avatar
Top here... I figure that if they request in the instructions to put it on top I think they have some kind of reasoning behind it.
Old Jun 6, 2004 | 07:15 PM
bowtiepwr's Avatar
>Thanks I reinstalled to the topside .
PCLZ28
Dec 24, 2015 05:19 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Latronaxe
Apr 29, 2015 08:25 AM
kksi
Mar 21, 2015 09:03 PM
Jazsun
Dec 29, 2014 12:14 PM
