aeromotive question
Old Aug 15, 2005 | 08:50 PM
limige's Avatar
aeromotive question
i'm mounting an a1000 and getting ready to wire it. i didn't get the directions with it, what size of wire/ relay are needed????
click link in sig for some pics of sump and pump setup.
Old Sep 5, 2005 | 06:59 PM
limige's Avatar
Re: aeromotive question
bump
Old Sep 5, 2005 | 07:11 PM
markinkc69z's Avatar
10-12 ga wire and a 40 amp relay.
Old Sep 5, 2005 | 07:13 PM
limige's Avatar
i've seen 30 amp relays but 40??? were do i look?
Old Sep 5, 2005 | 07:15 PM
limige's Avatar
also, should i eiliminate the stock relay and switch to the 40 amp there?
Old Sep 5, 2005 | 10:20 PM
ru2slo_99's Avatar
I used 8 gauge wire with a relay in the back and wired it up through a switch up front.
Old Sep 7, 2005 | 05:01 PM
mongse_1's Avatar
http://www.aeromotiveinc.com/usrbin/...umps/11101.pdf
Old Sep 9, 2005 | 12:36 PM
This is a late response but the 40 amp relay I mentioned is something that comes from Aeromotive supplied usually by Bosch. Working amperage is 30 as the A1000 has the potential to draw up to 25 amps or so when running high pressure such as under boost. If you use a relay rated for 30 amps continuous you will be fine.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
