94 Trans Am Rough Idle - Forced Induction
Old Jul 30, 2016 | 05:43 PM
Dams76's Avatar
Can someone take a look at my log file and provide some direction on what I need to do to get it running right. Attached is a log file from SCAN9495 of the car at idle. Also if I try to give it gas it tries to die out, this is not in the log file. I can take another log log of that if needed. Thank you for your help.
Here are my engine mods if it helps. Cam, port matched heads and intake, delteq, vortech s-trim, 60lb injectors, electric water pump, dual intank fuel pumps.
DavidS
Old Jul 31, 2016 | 10:53 AM
Re: 94 Trans Am Rough Idle
I'll take a quick look at it, but I haven't reviewed a lot of forced induction tunes.
Opening the log, it's not really useful. Run time is only 92 seconds, not enough for the PCM to go into closed loop. Typically, takes 206 seconds (programmed time out value) to enter closed loop, and coolant temp has to be above ~120*F. Your coolant temp has only reached 108*. Third requirement is O2 sensors hot enough to work, and flags indicate both left and right sensors are ready. Are you possibly running an open loop tune? If it's not an open loop tune, you have to start it and run it for at least 5 minutes to get anything meaningful. Probably a good idea even with an open loop tune, to get the coolant temp up to "normal".
Idle had a cyclic surge pattern. Programmed idle is 950 to 988 RPM (varies with coolant temp). Your idle is cycling up and down over a range of 850 - 1130 RPM. The IAC is not responding to the surge. Not sure if that is typical for a FI setup. Who tuned it?
Are you running a 1-bar MAP sensor tune?
I've seen people post logs for review in the Forced Induction forum. Not sure is they get any responses. In this case, I think it would be a good idea for me to copy this thread to the FI forum. Normally we don't like a thread posted in multiple forums, but there is not a lot of traffic on Forced Induction any more. But there are a few smart FI guys that will help if they show up.
Old Jul 31, 2016 | 08:29 PM
Dams76's Avatar
Than you for the reply. It's an Ed Wright tune. I'll get another log file tomorrow.
DavidS
Old Nov 29, 2016 | 08:41 PM
blown94's Avatar
Re: 94 Trans Am Rough Idle - Forced Induction
Lets start at the beginning. After being a tech for almost 2 decades now the first thing Ive come to realize in order to get to the bottom of the issue is start at the top. Whats the cars history, when were any changes/repairs/mods performed and when was the last time it "ran correctly". When did the issue start basically?
Its like going to the doctor after you havent been for awhile, need to catch up with the past to get to the present. Ive come across a few issues along the way and might be able to add some useful diagnotics.
First thing that comes to mind is going to be the MAF, or an air/vacuum leak. I used to blow my intake tube off on decel and the car barely ran. Few others come to mind, but need more detalis.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
pete53
Jun 27, 2015 09:08 AM
eagle54348
Jun 15, 2015 05:00 PM
MadMav
Jun 8, 2015 11:38 PM
Bignasty85
May 8, 2015 11:48 PM
