9:1 compression too much for 15psi?
Old Jun 4, 2004 | 12:38 PM
  #16
T/A lt1's Avatar
Not trying to rob your thread but I have been contemplating selling my shortblock or longblock and building a lowcompression 355" LT1 setup to run 15+psi. I would run a T-trim or lower the compression and run the D3 Procharger I have but don't know if I could make it fit. My question is how would a heads/cam low compression with say 12psi stack up to my 150-175hpN2o setup I am currently running? My car ran on a 150 shot- 1.60-1.63 60's 10.80's@126mph 3550lbs raceweight, 3.42's and 3500converter and +3000' DA this past weekend. I would think I could run 10.50's@128-130mph with the blower and then a little gas on top of that could get down in the lower 10teens or so?
Brady what was the part# on those TRW's and what size dish were they? Would I be better off with a 454 BBC on gas than a supercharged and N20 355" LT1? I have the K-member in my car to run BBC or SBC so it wouldn't be too tough to swap and I already have a 454 LS6 shortblock. LMK Later Clint
Old Jun 5, 2004 | 06:26 AM
  #17
chevyguy3's Avatar
i am currently at 17-18psi with 9.2:1 compression and 92 octane. i have had no problems with detonation. i have the vortech aftercooler without the large water tank and am running 28-29* timing across the board at WOT
Old Jun 5, 2004 | 09:36 AM
  #18
MEAN LT1's Avatar
wow....thats alot of timing and boost for pump gas. I had no idea you could run a setup like that on 92. Must be some good 92
Old Jun 5, 2004 | 10:11 AM
  #19
JZ 97 SS 1500's Avatar
The water to air setup is helping ALOT. Typical IAT's with a good Air to Air still see north of 140-150, vs a good water to air will see 85-90 degs. Heck Mike Barreras mustang dynoed 1200hp and saw IAT's of 85 degs
Jose
Old Jun 5, 2004 | 06:46 PM
  #20
chevyguy3's Avatar
i havent given them a good look yet at 17-18psi, but on 12psi my IATs were ~95 at part throttle, ~120-125 in the boost WOT. there are 2 water coolers on my setup, but i might be taking one off since its taking too much air from the radiator and i have nowhere else to put it
Old Jun 6, 2004 | 11:22 AM
  #21
RealQuick's Avatar
What was your hp/tq if you dont mind me asking...
Old Jun 6, 2004 | 09:47 PM
  #22
chevyguy3's Avatar
havent gotten it on a dyno yet. trying to get the tune a little closer on the street/track before i go blowing $ wasting extra time on the dyno that i wont need to once i get it dialed in a little better here first. also am about to change some parts on the engine so im waiting till i do that to pay $ for the dyno time to get it tuned in since the tune will just be off after i make those changes. hopefully ill be turning the rollers in 2-3 weeks
Old Jun 6, 2004 | 11:32 PM
  #23
'68LT1camaro's Avatar
Hey Chevy Guy 3, which supercharger are you running? That's a gang of boost with intercooling! I'm using SPEED PRO pistons, part# L2441F with a 21cc dish. Which pistons do you use?
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
