60lbs or 75 lbs Injectors
Old Mar 10, 2006 | 09:04 AM
xxsaint69x's Avatar
What is the max hp that the 60lb mototronHi IND injector will support?
Did they release the 72lb version yet, and where is the best place to buy them from?
Marcin
Old Mar 10, 2006 | 09:14 AM
rskrause's Avatar
Moderator
Re: 60lbs or 75 lbs Injectors
Depends on fuel pressure and BSFC. But in general, in a SC V-8 running in the 45psi range (boost referenced) 60lb injectors ought to be good to ~750hp.
Rich
Old Mar 10, 2006 | 09:31 AM
RealQuick's Avatar
Those 60's supported a 700rwhp sts car.
Old Mar 10, 2006 | 10:45 AM
ZBLKHELLRZR's Avatar
I went w/ RC high Z 72's. Bit more expensive but they'll handle 1000hp. Should have them next wk I hope.
Old Mar 10, 2006 | 10:55 AM
xxsaint69x's Avatar
where did u order them from and how much
Old Mar 10, 2006 | 12:14 PM
Marcin I bought them from Lightning Motorsports. 780 bucks. Can't remember the guy I spoke to but I asked if he had them for LT1's and he did and in stock, also come w/ flow sheet. Could've bought them direct from RC but I could never get them to answer their phone.
Old Mar 10, 2006 | 12:25 PM
RealQuick's Avatar
You took it dry bro! Damn...$100 a piece. For that price you might as well jus buy low impdednce 72's for 300-350shippd (i see them all the time forsale) and buy an impedence converter fo $250-300. Atleast you have room to grow down the road.
Old Mar 10, 2006 | 12:43 PM
T/A KID's Avatar
60 motrons will be what I run on my VRE 383, D1SC 12lbs, Ported AFR heads, combo, like someone said before should handle 700-750RWHP.
Old Mar 10, 2006 | 01:02 PM
I've never seen low impedance for the price you've stated. Ever. I sure as hell wasn't gonna buy used and the impedance box was a no-no for me. I don't do wires. LOL! Also at the time I wasn't sure if I was gonna risk it (the engine) and have faith on some make shift mail order tune and if I did at least I didn't have to worry about the injectors not being high Z's. I eventually came to the realization of just getting a stand alone unit but the injectors actually forced me to go that route. So I payed a pretty price and did take it dry but I wanted high Z's. It wasn't my $$ anyways. But I see you point.
Still everywhere I've looked low Z's are 75-90 bucks a pop except Racetronix.
Doh!
Old Mar 10, 2006 | 01:07 PM
97WS6SCharged's Avatar
Flow matched 83's for $60/ea.
http://www.racetronix.com/3105FM.html
Old Mar 10, 2006 | 02:01 PM
Yeah I saw that. LOL! No sweat. These will handle 1000 and I will get close to 800-850 if I'm lucky.
Old Mar 10, 2006 | 02:09 PM
Roadie's Avatar
i bought 75lb/hr injectors for $270 shipped and a used accelleronics box for $200 shipped. Ya just gotta look around instead of impulse buying.
Old Mar 10, 2006 | 02:42 PM
RealQuick's Avatar
I am talking used on the injectors. I have no problem buying injectors used. Set your injecto constant and make sure everything looks good at idle and part throttle. Should be fine at WOT once you have determined the size of the injectors is correct in the tune.
Old Mar 10, 2006 | 02:43 PM
RealQuick's Avatar
Why do need so much fuel for a 350rwhp combo... It'll never make power
Old Mar 10, 2006 | 03:00 PM
Roadie's Avatar
It's all about the flamethrower exhaust mod. It needs to be running super rich to get 15ft flames out the tailpipes.
