355 LT1 Turbo initial dyno numbers
Old Sep 6, 2006 | 07:43 PM
  #16
ChrisUlrich's Avatar
Re: 355 LT1 Turbo initial dyno numbers
What size wheel is in that T70?
Old Sep 6, 2006 | 10:26 PM
  #17
Shankels94TA's Avatar
In process of tearing the car down still but the end is near!!!
TransAm396- the wastegate is a tial 38mm and has been plenty tricky in setup
ChrisUlrich- P trim turbine wheel
Old Sep 7, 2006 | 01:52 AM
  #18
1BigBird3's Avatar
That is one sweet lookin' setup!
Let us know how it does when you finally get to open her up!
Ruben F.
Old Sep 7, 2006 | 05:33 AM
  #19
What size in mm is a P Trim? haha Excuse my ignorance!
Old Sep 7, 2006 | 07:14 AM
  #20
Under_Pressure's Avatar
P-Trim is a larger than normal wheel. Its more laggy because of weight but its stronger for high boost.
Those Master Power turbos seem good. I had one in my drag civic but I only had that car for a month. Might boost my LT1 looking into a t-70 too.
Old Sep 7, 2006 | 11:24 AM
  #21
Larger then normal... but whats normal? I don't mean to nitpick but I am just curious of the size of the trim in mm.
I am going to be boosting my 385 LT1 and I want to use an 80mm wheel in a T76GTS-H. I like the results I could be seeing A LOT on ONLY 10lbs when I plan to boost 20lbs.
Old Sep 7, 2006 | 05:21 PM
  #22
The way I see it the stage 5 turbine wheel is a good choice for those looking at a Hi-HP street & strip monsters while the P-Trim and Q-Trim have a large amount of lag and should ONLY be used by those looking to obtain 700 + HP with supporting mods. The turbine's also change when going P or Q trim. Ill see if I can get the exact size but the big about almost twice the size.
Old Sep 9, 2006 | 09:36 AM
  #23
JZ 97 SS 1500's Avatar
That's great if these were 150ci engines. . You obviously haven't driven a 350 SBC with a 76MPS,76GTS or GT42.
Old Sep 13, 2006 | 12:17 PM
  #24
will62085's Avatar
If your goin with spec, just go stage 5, skip the stage 4...it still drives very nice, just barely stiffer than my old stage 3i. I see you live in GA, if you want, come by (Kennesaw) and you can drive my car to get a feel for the clutch if you'de like. Personally, i love it so far, and SPEC has been extraordinarily good to me in the past...
Old Oct 12, 2006 | 12:28 AM
  #25
96SilverRam's Avatar
That is one sick 25th T/A !!! I'm glad you documented the PTK kit with pics on your car domain site.
Nice job
Old Oct 12, 2006 | 04:20 AM
  #26
LT1runner's Avatar
What have you done to your stock heads? I hope nothing, but I was thinking you may have had them ported.
Old Oct 12, 2006 | 08:52 AM
  #27
RealQuick's Avatar
He stated ported in the first post...
Old Oct 13, 2006 | 09:25 AM
  #28
Howdy folks...its been awhile. The car is back together and should be running soon. Plumbing the intercooler water system with all braided lines has been a hassle but worth it. Ill post some more pics shortly and some vids once its running.
Lt1runner- I cleaned up and port matched the stock lt1 heads myself. I also installed ferrea valves with beehive springs. Why would you hope not?
Thanks again for all the kind words....any comments are always welcome.
Old Oct 13, 2006 | 01:22 PM
  #29
We want more pics
Old Oct 19, 2006 | 02:21 PM
  #30
blkchevyz's Avatar
whats your bottom end consist of?
compression?
nice setup
