20psi with S trim?
Old Jan 21, 2004 | 04:40 PM
  #31
BOOST FED 95Z's Avatar
Mike, W/ a 6.66 and a 2.75" you are seeing 13-14 psi w/ an AFR headed 383 ci.....I wonder why I am only seeing 11-12 psi w/ the exact same pulley combo on a stock headed 355 ci....I am running the cc 224/236. W/ my S-Trim and a 2.75" pulley I only saw around 9 psi. I have a 7" waiting to go on once I hit the dyno, I just think its a little weird that I am not seeing anymore boost than I am.
Scott
Old Jan 21, 2004 | 04:45 PM
  #32
Highlander's Avatar
Probably S-trim vs T-trim difference.. there are 200CFM difference between them
Old Jan 21, 2004 | 06:17 PM
  #33
Thats what I have is a t-trim now...I sold my s-trim and bought a t-trim and with that pulley combo I am only making 11-12 psi...w/ my s-trim i saw around 9....Doesnt this sound a little low to you guys?
Scott
Old Jan 21, 2004 | 06:41 PM
  #34
rskrause's Avatar
Moderator
Scott
Intake restriction? I saw a 2-3psi gain with the S-trim from replacing the "dryer hose" with a solid pipe. With the F1, running it without any intake piping gains 4-5psi.
Rich Krause
Old Jan 21, 2004 | 06:47 PM
  #35
engineermike's Avatar
I do have a hard intake pipe, as well as a fully ported and bored MAF.
Something else to consider is that the Vortech bypass valve leaks over 10 psi. I replaced mine with a used Eclipse 2G unit, which is good to 15 psi.
Mike
Old Jan 21, 2004 | 07:08 PM
  #36
Highlander's Avatar
Which bypass? the mondo? or the plastic one?
Old Jan 21, 2004 | 07:47 PM
  #37
The plastic junk.
Not all of them leak, but INTMD8 picked up ~45 rwhp with his S-trim by replacing the Vortech bypass valve.
On the other hand, LJ has run 9.90 at 139 mph with the plastic Vortech bypass valve. . .
Mike
Old Jan 22, 2004 | 11:20 AM
  #38
I think I will try both of those but first replace the bypass valve.....Do you recommend the mondo or the eclipse unit.
Scott
Old Jan 22, 2004 | 05:10 PM
  #39
Eclipse 2G valve: $20 used (The DSM guys upgrade to the 1G valve because it will hold 20 psi).
Mondo: $240
You decide. . .
The Eclipse valve also has hose conections and is roughly the same size and shape as the Vortech so it can be adapted easily.
Mike
Old Jan 22, 2004 | 06:22 PM
  #40
Mike, so there is not alot of fabrication to be done w/ the eclipse unit?
Scott
Old Jan 22, 2004 | 06:25 PM
  #41
The Eclipse unit is very similar to the Vortech, but all hose connections (inlet, outlet, and vacuum) are all one size larger, so you have to play with different size hoses to make it fit.
Mike
Old Jan 23, 2004 | 10:10 AM
  #42
Pro Stock John's Avatar
You can make 20 psi thru a stock LT1 if you make the overall combo as inefficient as possible.
Realistically, if it's all about the boost numbers, I'd try to run new valve springs, straight 104 u/l, and pulley it for 15psi. I'm think you'd make about 550-600rwhp for about a summer.
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
cmsmith
Sep 14, 2015 09:25 PM
tdigger9899
Sep 7, 2015 10:56 AM
CARiD
Jul 7, 2015 08:19 AM
