2 bar MAP part numbers
Old Jul 24, 2013 | 08:39 AM
NJ-LE's Avatar
I've found two Gm 2 bar MAP sensor numbers. 16040609 (old number) ... 12569241 (new number) Are these the numbers for a 2 bar GM MAP sensor that will mount the same way as the stock 95 LT1 MAP sensor and use the stock pigtail? If not, what is the right part number?
Old Jul 25, 2013 | 02:18 AM
97WS6SCharged's Avatar
Re: 2 bar MAP part numbers
12569241 should work. You can also look up the map sensor for a GMC Syclone/Typhoon truck.
Old Jul 28, 2013 | 10:24 AM
NJ-LE's Avatar
97WS6SCharged:
Thanks for replying. I'll order one and fight the programming battle. It's a daily driver so I'll try to discover if having 3 or so different values of boost (1 bar +) spark retard hurts 'normal' driveability.
Old Jul 29, 2013 | 03:57 PM
DirtyDaveW's Avatar
https://www.camaroz28.com/forums/for...40-kpa-869350/
Old Jul 30, 2013 | 06:29 AM
NJ-LE's Avatar
DirtyDaveW:
So that's where the pressure vs voltage table went to. I knew I'd seen it but couldn't remember where. Now I won't have to break out the test gauge, tubing and bicycle pump to make one. Many thanks!
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
