What size cats in/out 96 firebird
Old May 13, 2008 | 11:07 AM
dan22q's Avatar
Im going to order new Magnaflow spun cats and need to know if the in/out is 2.25" or 2.5". Also should i get the offset ones or straight ones?
Old May 13, 2008 | 11:26 PM
dan22q's Avatar
Stock manifolds and y pipe. What I want to know is if i can just replace stock cats with small universal cats in the y and maybe add a small filler section. Or do i have to have a new y put in. The drivers side cat is welded right to the manifold flange like every other 96 - 97 f body. And theres a bend right after the cat. So can i fit a small 8" long cat in the stock y pipe and do i need it offset on the exit side of the drivers side cat? I would think this would be a common situation. Anyone whos done this please let me know.
Old May 17, 2008 | 07:51 PM
mzgp5x's Avatar
Well... I went to FI (97 - 383 - D1 M6) with dual cat Random Y pipe. It flows good. But, recently blew out the right side cat. Both cats were positioned under the passenger seat side. They performed well. They could not withstand the pressure/ flow loading of the Procharger D1. B.
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
TechCam97
Sep 12, 2002 07:20 PM
