SLP Craftsman stubby spark plug socket
Old Mar 10, 2009 | 10:05 PM
mrmint69's Avatar
I have Pacesetter Mid headers. I had someone else try to pull my back drivers plug and they could not get it without this. He's been a certified tech for 12 years and none of his tools or tricks worked. It fits on and you use a 19mm wrench to loosen it. This thing is a real life saver.http://store.summitracing.com/partde...5&autoview=sku
Old Mar 10, 2009 | 10:13 PM
Spartan7's Avatar
I use one of those too. That and a ratcheting box end, makes it a whole lot easier.
Old Mar 10, 2009 | 11:45 PM
SLP is basically buying a less-than-$5 5/8" spark plug socket, cutting it down, and charging you $30 for it....... think about it. You could do the same thing with a Craftsman socket and a hacksaw.
Old Mar 11, 2009 | 12:09 AM
mrmint69's Avatar
I think the price is crazy but don't think outside the box like you. I now will buy a hacksaw and make my own if I lose this one.
Old Mar 11, 2009 | 01:37 AM
madhatter's Avatar
Get the cheapest one you can. You will also have to drill out the socket drive.
Old Mar 11, 2009 | 04:43 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I used a socket that I believe was a 1/2" drive, and a pair of vice grips.
Old Mar 18, 2009 | 06:53 AM
PoorMan's Avatar
They did something similar with are Z28s and TransAms. They just did some simple boltons and called them either a SS or Firehawk. Did it myself and safed alot more than $30.
Old Mar 30, 2009 | 08:41 PM
josh77888's Avatar
just buy a set of Go-Thru sockets. Local advance auto parts has a full set for 15 bucks. works great for that and other projects.
Old Apr 18, 2009 | 09:17 AM
caldercay's Avatar
You mean, like this?
http://picasaweb.google.com/calder.c...20472584205154
I made that to use after installing the Kooks.
Old Apr 18, 2009 | 10:25 AM
Fuels94TA's Avatar
I made mine about 2 years ago and love it...
Old Apr 18, 2009 | 09:52 PM
I have a "collapsing" socket from The Eastwood Company - not sure if they make it any more. Its has three telescoping sections that allow it to collapse to 3/4" to get it over the plug. Than as you push it down over the hex on the plug, the upper sections pop out, and each has a hex on it that can be turned with a wrench.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
nikko
Apr 20, 2015 07:56 AM
racecarz28
Mar 30, 2015 09:55 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
