Slip fit header flanges?
Old Dec 21, 2006 | 10:00 PM
WonQuickZ28's Avatar
So Im fed up with my weakly sealing three bolt flanges on the collectors of my headers connecting to my y-pipe. So Im thinking about just cutting them off and getting a y-pipe to slip over the collectors and band clamping it. I know some LS1 headers work like that, if anyone has thought of this or tried please give me some heads up. Thanks in advance.
Old Dec 22, 2006 | 01:43 PM
2000GTP's Avatar
The Pacesetter headers work like that. I have had no leaks at all with my slip fit Pacesetter long tubes. I am using the 3" band clamps as well and have had no issues with them either. Frankly, I think it is a pretty good setup, the slip fit offers slightly better ground clearance over the flanged headers and the fact that everything is held together with band clamps makes future disassembly a breeze.
Old Dec 23, 2006 | 02:51 PM
wrd1972's Avatar
Are the flanges warped?
What gasket are you using?
Are you using stage 8 locking collector bolts?
Sealing the collectors is not brain surgery, why not address the real problem. I have three bolt flanges that are sealed tight using aluminum gaskets and stage 8 bolts. Slip fits are a bitch to get off when the time comes.
Old Dec 23, 2006 | 05:36 PM
streetbad's Avatar
Torca clamps with torca slots just like factory. Three bolt flanges are only for cars with carburators and front drum brakes.
Old Dec 23, 2006 | 09:10 PM
i have aluminum gaskets and neither flanges are warped. the only pita in using slip fits is if you use the u-bolt style exhaust clamps and not the band clamps.
Old Dec 24, 2006 | 02:20 PM
2000GTP's Avatar
Exactly why I don't use the u-clamps. The band clamps seal just as well and they don't badly distort the pipes in the process.
Keenan
Jan 19, 2023 12:24 PM
RUENUF
Mar 13, 2016 03:39 PM
jackpawt883
Feb 26, 2015 09:04 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
