removing muffler
Old Apr 21, 2008 | 10:41 PM
ARZ28's Avatar
removing muffler
i have a 94 z28 lt1 and i was wondering if someone made a pipe to fit where muffler would go if i took it off and just ran cat with tail pipes?
Old Apr 22, 2008 | 09:27 AM
2000GTP's Avatar
Are you looking for a weight savings difference, or just after a different sound? Putting a 30 dollar cutout right before the rear axle dump would give you the same effect without having to chop out the muffler.
Old Apr 22, 2008 | 09:32 AM
6Speed's Avatar
Muffler should be pretty easy to remove, but I think teh tailpipes are welded to it. You would probably need to by a couple pieces of straight pipe, a 90 degree bend, exhaust hanger, and some clamps.
Should sound exactly like borla w/ no plate.
Old Apr 22, 2008 | 05:58 PM
Jazsun's Avatar
The only which is nice about going straight pipes vs. cutout is you wouldn't get the vibration from the cutout. Mine rattles all my change and everything.
Old Apr 23, 2008 | 08:48 PM
ARZ28's Avatar
i would like to just take muffler out and keep the stock appearence and keep the tailpipes in place and have some sound.
Old Apr 24, 2008 | 07:30 PM
dan22q's Avatar
You have two options. A muffler eliminator on ebay $25. This is set up so its end line up where the old muffler did. This is very easy to weld on. It is pretty restrictive though due to the design. Best way is to pay a little more to have a shop make one for you. They can y right off the 3" I pipe.
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
