ratteling coming from catalytic converter?
Lately Ive been hearing this ratteling noise coming from the cat I think. It almost sounds like some pieces are ratteling around in the cat. Is that possible? Time for a new one?
Re: ratteling coming from catalytic converter?
Possible... the catalyst is embedded in a ceramic honeycomb substrate. Overheat it and it can be damaged, melting or breaking up. But before jumping to conclusions, get under the car and pound on the shell to see if it rattles.
Tried that and it rattled. Is it bad to drive around like that? Also, where can I find a new part?
You're OK until something plugs up the exhaust. Then you'll start to lose power.
Have no idea what replacement parts are available. The original cat was welded to the Y-pipe. Since you have a BBK Y-pipe, yours will already have been cut off. You can probably find a "universal" replacement converter for $125-150. It would have to be installed by a muffler shop. Hopefully, NY is not as demanding as CA, where all replacements have to be specifically CARB-EO certified.
I looked at Summit and they had several different brands. Search on "1994 Camaro Z28 catalytic converter".
1994 CHEVROLET CAMARO Z28 Catalytic Converters - Free Shipping on Orders Over $99 at Summit Racing
It's "universal" and may require a muffler shop to connect it to your Y-pipe and flange it to match the catback. If you have the stock cat, it has already been cut off the stock Y-pipe, and someone had to figure out how to attach it to the BBK Y-pipe.
Check the length shown in the listing to make sure it matches the space you have available.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
