ps lt's and stock ta
Old May 1, 2007 | 12:22 PM
custom95's Avatar
I going to be using pacesetter lt's and ory pipe with stock torque arm, are there any clearance issues in doing so? I've heard that some aftermarket ta's present clearance issues but I have not heard of any problems with the stocker. Is this correct?
thanks
Old May 1, 2007 | 06:02 PM
2000GTP's Avatar
You should be fine. I had a slight rubbing under hard accelaration with the y-pipe and the stock torque arm. I did a simple "band-aid" repair and wrapped that part of the y-pipe with some header wrap to dampen the noise. My motor mounts are old and worn though, so I'm sure if I had replaced those, then there wouldn't have been any clearance issues as that is usually the cause.
Old May 1, 2007 | 10:19 PM
custom95's Avatar
Thanks 2000gtp, I'm changing out my motor mounts when I do the install so I should not have any trouble.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
