o2
Old May 13, 2010 | 07:29 AM
awill12's Avatar
o2
ok so if i put on pacesetter lt headers with no EGR and cat delete and air pump delete and have the mail order tune take care of this. do i still need to run o2 sensors? thanks for the help.
mods on the way comp cam (k07-466-8) (rpm1418-16) part numbers 218-224.570.565 cam with lifts,springs,push rods,chain,1.6 rrs,pacesetter lt headers,mail order tune, slicks
Old May 13, 2010 | 12:10 PM
You can delete the after-cat O2 sensors. They are only there to verify the cats are operating. They can be "tuned out" of the PCM, to prevent a code or SES light.
The pre-cat sensors are required by the PCM to allow it to control the A/F ratio, and to react to changes that throw the A/F ratio off spec. You cannot delete the two pre-cat sensors, unless you choose an "open loop" tune. Running in open loop means the PCM can no longer use the long term fuel corrections to compensate for changes to the engine's operating conditions - e.g. - changes in fuel pressure, changes to the MAF calibration (dirt), minor vacuum leaks, etc.
Old May 13, 2010 | 12:36 PM
awill12's Avatar
injuneer
thanks agine man u have been alot of help with all my questions
