New exhaust!!
Old May 17, 2010 | 07:06 AM
StangCrusher350's Avatar
New exhaust!!
hey everyone. i got the new exhaust on. nothing much different than what every other person has here. Pacesetter LT's into 3'' x pipe into 3''inlet 3'' outlet Flowmaster 9430109 10 Series Race Mufflers. the system is held up by the rear seat belt bolt holes with 12 mm bolts 1.75'' long i bought. the system is currently being help together with clamps......BIG MISTAKE!!! as you and i all should know, the exhaust clamps nearest the mid section of the car can and i promise you will bottom out on every single little bump you come into contact with. the exhaust needs welded together other that that no problems and sounds great. pics can posted if anyone wants to see
Old May 17, 2010 | 06:15 PM
Procharged94Lt1's Avatar
Get a set of stainless band-clamps from Summit or anywhere else. I used those front to back on my car and zero ground clearance issues and you can pull the exhaust just as quick as you put it on that way should you need to.
http://www.summitracing.com/parts/WLK-33272/
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
