Need headers with less ground clearance?
Old Sep 9, 2008 | 10:17 AM
Gtpguy's Avatar
So I have pacesetter long tubes and the driver side hits the floor board. I have poly mounts in there, but it only helped 50%. Now my car was in an accident before I got it, so the frame is most likely tweaked ever so much. I'm sure that has some to do with it. But if I can lower the headers 1/2 inch, the rubbing would be gone.
I'm thinking of selling my LTs to my brother, and buying another brand that will give me the clearance I need. What brand is known for low little clearance? My car is lowered, but I can deal with a scrape once in awhile.
Or what else can I try? Poly tranny mount? Tranny mount spacer to change the angle ever so much? What about some sort of heat resistant material jammed up between the header and the floorboard? What??
Old Sep 9, 2008 | 04:52 PM
2000GTP's Avatar
Probably go with some mid-lengths this time around.
Old Sep 9, 2008 | 05:23 PM
JMG97SS's Avatar
Maybe the hookers will clear better, I know mine hangs pretty low.
Old Sep 9, 2008 | 06:03 PM
Green96Z's Avatar
My Kooks clear nice, but then they're expensive. Why don't you try a little "clearancing" with a hammer?
Old Sep 9, 2008 | 07:17 PM
wrd1972's Avatar
Whoaa mule!!!
Here are some ideas to get more clearance.
1. Elongate or enlarge the header bolt holes to allow the rear of the header to hang a bit lower.
2. Put some spacers between the transmission cross member and the chassis to allow the motor to tip down a bit.
3. Put the car on a lift, disconnect the y-pipe, and pull the header down if you can. Get enough weight hanging on it and it should bend downward some.
My left side LPP header at the collector can easily shift up and down (bolts barely snug) 3/4" or so.
Old Sep 9, 2008 | 07:22 PM
2000GTP's Avatar
The Pacesetters tuck up very nicely, if those are dragging, I'm sure other long tube brands will not fare much better.
Old Sep 10, 2008 | 02:14 PM
Gtpguy's Avatar
wrd1972, I'll try #2 and #3. How thick of a spacer do you think I can run safely?
GTP, I've read that there are other headers that don't give good ground clearance and that Pacesetters do. But, I'm in no hurry to remove them yet to install even more pita headers. The install was dramatic.
Old Sep 11, 2008 | 11:56 AM
wrd1972's Avatar
Max I would consider would be 1/2". Start at 1/4".
And was there ever a LT1 header install that was NOT dramatic. I hear crickets.
Old Sep 11, 2008 | 01:07 PM
onebadponcho's Avatar
Wow, I'm having clearance problems with my AS&Ms (passenger side collector hangs too low and hits k-member); I can't believe I didn't think of this stuff.
Someone could probably make a whole soap opera series based solely on LT1 header install drama.
Old Sep 11, 2008 | 03:18 PM
wrd1972's Avatar
I had a clearance issue with my RK Sports headers which are near identical to the AS&M's. You will need to trim the k-member just enough to keep it from banging. If that is the only clearance issue you have your lucky. Its the steering shaft thats the PITA on RK's.
Old Sep 11, 2008 | 03:43 PM
Gtpguy's Avatar
I didn't have trouble with the linkage, other than not connecting it correctly. Which left me stranded in a mcdonalds parking lot. I won't cut the car up, unless I really REALLY have to. Not that this car is a garage queen, I just don't have the skill or know of someone that has any either. I'm going to try the spacer thing tomorrow.
Old Sep 16, 2008 | 08:35 PM
6SpdLT1Z's Avatar
hooker/lpp or get some mids
Old Sep 17, 2008 | 09:23 AM
slomarao's Avatar
lpp of kooks, other than that get some shorties, mids.
Fastbird93
Apr 9, 2016 07:01 PM
Drtryder
Apr 22, 2015 04:17 PM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
centric
Aug 15, 2002 09:04 PM
