Need header ideas please!
Old Oct 25, 2008 | 10:22 PM
Mikes93Formula's Avatar
I have a 95 z28 and was wondering what type/brand headers to get.I want longtubes but concerned the inspection place will fail me for no cat even though i don't have to do emissions anymore.Can they do that?Obvisouly if i have no cat that means getting rid of the a.i.r system.Will this cause the ses light to come on..do i need that tuned out?Is there anyway to retain the cat and all emission equip or is that just for mid tubes?I ain't getting these till after xmas so i got time for a decision,but im trying to find the best for my car.Any help is appreciated
Mike
Old Nov 5, 2008 | 04:05 PM
2000GTP's Avatar
If you are emissions exempt and don't have to go in for an inspection anymore then you shouldn't have anything to worry about. As for the type of header you are after, I would do a search on the subject. There have been alot of posts on this topic and quite a bit of good information is floating around.
Old Nov 5, 2008 | 04:20 PM
JakeRobb's Avatar
Super Moderator
IMO, if you're getting longtubes, your best bet in the long run is going to be stainless steel with equal-length primaries. For my LS1, I'm a fan of QTP, and they have an LT1 set too. Headers of this type afford the largest increase in power and the most reliability. They're more expensive (expect to pay at least $800 for a set), but fitment is generally better (that means easier installation) and it will keep your underhood temps from getting too high.
You can go the cheap route (something like Pacesetters, which are mild steel and do not have equal-length primaries, but only cost $300-350), but you will sacrifice a bunch of power and torque, and they won't hold the heat as well.
In either case, you can further improve the heat situation by getting your headers ceramic coated by a place like JetHot.
Whatever headers you choose, make sure to also get a matching Y-pipe.
Quality of the headers aside, yes, you can still have a catalytic converter in the system if you so choose. You can't re-use the stock one(s), and the replacement(s) will not be in the stock location. This option costs more, and is still illegal in some states. I'm not sure what the laws are in Massachusetts.
Old Nov 5, 2008 | 04:29 PM
2000GTP's Avatar
I have been out of touch with the LT1 stuff for a little while now, did QTP just recently start making LT1 headers? I wasn't aware they made a set, I know Kooks caters to both the LT1 and LS1 crowds.
Old Nov 5, 2008 | 04:32 PM
JakeRobb's Avatar
Super Moderator
I thought they had, but I just checked their site and I don't see it.
Kooks is a good choice too.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Killer94z
Jan 13, 2015 12:06 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
