as&m with BMR K-Member random tech y clearance
Old Nov 16, 2008 | 01:43 PM
merim123's Avatar
Hey guys, I've been searching all morning trying to see if this has been covered before, I haven't been able to find the right search terms if it has.
I've got the motor out of the car and am assembling everything on it so that I can put it in from the bottom. As I started putting the AS&M driver side header on, I noticed it is extremely tight clearance on the BMR K-member and also, when I put the random cat Y on, it makes contact with the oil pan so that doesn't seem right either. I haven't torqued all the bolts down yet, but i don't think I can get that much more clearance on it by torquing it down, all the bolts are on tight. on the header. Any thoughts ?
Old Nov 22, 2008 | 11:46 PM
merim123's Avatar
I've got it all torqued down and i'm still getting contact on the driver side of the oilpan. it looks as if I may need to have to have the ypipe cut and rebent a bit.
Sometimes buying used stuff saves money, but leaves you kind of in an unknown situation. I'll post pics later for future reference for others.
Old Nov 23, 2008 | 05:01 PM
merim123's Avatar
Here's a pic of the interference. The motor mount tab of the kmember is in direct contact with the collector flange...
And this is the close up...
This pic doesn't show the ypipe making contact with the oil pan either. So I'm on the look for long tubes...
HOpe this helps others.
Old Dec 3, 2008 | 07:36 PM
HottestZ28's Avatar
so whats the scoop. I want a tubular K-member and I already have AS&M headers with their y-pipe.
Can you just clearance the motor plate on the k-member?
Old Dec 3, 2008 | 08:08 PM
merim123's Avatar
you can if you want, i got it all to bolt up but as you can see it was resting on the k-member, i went another route, went LPP's.
97blackformula
Aug 27, 2015 06:02 PM
realistyc
Jul 28, 2015 07:32 PM
Jcastro2333
Jul 27, 2015 09:49 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
