Loud idle, Quiet WOT?
Old Dec 13, 2006 | 08:33 PM
JP95ZM6's Avatar
Believe it or not, I want my car to be as quiet as possible at WOT. The more I can get on it without attracting attention, the more fun I can have. I own another car that just SCREAMS at WOT/high RPM, and more than once the noise has made the difference in my getting noticed by the local enforcers.
So, is there a muffler/catback that is pretty quiet at high RPM/WOT, but still has healthy idle? I'd give up 5 peak HP in the Z28 if it means I will be able to use 50 HP more around town at the same noise level! That's why I picked the Flowmaster 80 Series I'm currently running, but if there is a better choice, I'm interested.
Thanks.
Old Dec 14, 2006 | 07:33 AM
teke184's Avatar
um.....NO....
Old Dec 14, 2006 | 11:07 AM
Unertl42's Avatar
i'm pretty sure that isn't possible, unless you rig up a device that can separate your y-pipe and headers at idle, and reconnect them at wot.
Old Dec 14, 2006 | 02:30 PM
LT1 POWR's Avatar
Something like a reverse Z06 setup would work. They have a bypass(cutout) that opens up at WOT for better flow. I Guess you could get on of those or an electric cutout and rig it up to open at idie and close while under throttle and run a stock or quiet catback.
Old Dec 14, 2006 | 02:49 PM
95LT1conv's Avatar
buy a 4 cyl car
Old Dec 14, 2006 | 03:00 PM
CamaroRacing12's Avatar
Originally Posted by 95LT1conv
buy a 4 cyl car
hahaha...
the only thing i could think of is a e-cutout.... in theory it would work... but prolly would be more of a PITA then nething else... and u prolly would just leave it open or shut all the time neways
Old Dec 14, 2006 | 03:01 PM
BradcTA's Avatar
Get a stock catback and cat and run an electric cutout for when you want it loud at idle (for your cam I suppose). Your not going to get any quieter than the stock catback unless you run TD with 2 mufflers on each side.
Old Dec 14, 2006 | 06:07 PM
teke184's Avatar
yeah true duals will give you a killer sound at idle...like no catback will.
but it still can be made to be very tame at full throttle with the right muffler setup
Old Dec 14, 2006 | 06:09 PM
JP95ZM6's Avatar
Oh, come on now. I meant RELATIVELY quiet idle. I can't believe some of you thought I meant quieter at WOT than IDLE. Although those are some creative attempts to answer what must have sounded like a pretty stupid question if that's how you interpreted it.
Different muffler styles have differerent attenuation curves vs. flow and frequency. I want to know which ones have highter attenuation at high flow & pulse amplitude, lower attenuation at low flow... Or more accurately, one with a lower falloff rate with increasing amplitude and frequency. The only way I know to do that by design is with a very large volume, but I'm sure there are variations among what is on the market already.
I frequently read 'it's quiet at idle, but screams at WOT'. So, which mufflers would you NOT say that about?
Last edited by JP95ZM6; Jan 14, 2007 at 10:50 AM. Reason: Reversed WOT and IDLE, typo.
Old Dec 14, 2006 | 06:10 PM
JP95ZM6's Avatar
Thanks Teke184, now were on the right track. Which setup?
Old Dec 15, 2006 | 12:24 PM
reamo04's Avatar
hooker mufflers are generally pretty quiet, u could run that and an e-cutout
Old Jan 13, 2007 | 09:56 PM
metallicsniper's Avatar
get an electric cut out and keep the stock exhaust. open the cutout while idle, then close it when WOT
sherwinZ28
11
Aug 15, 2015 05:38 PM
Xiantyl
Jul 21, 2015 05:42 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Latronaxe
Jul 17, 2015 11:55 AM
