I need help with exhaust cutouts. Info Please.
Old May 9, 2007 | 03:57 PM
kendall5000's Avatar
Exclamation I need help with exhaust cutouts. Info Please.
My 93 z28 just doesn't quite sound loud enough and someone posted i should get cutouts. So i have decided to go with that but i don't that much about them. what kind do i need/ where should it go (right after the header?) should i get an electric one /where can i buy one
Old May 9, 2007 | 03:59 PM
2000GTP's Avatar
The common place is right before the rear axle dump in the intermediate pipe. A 3" cutout is the size you should go with. Check out the supporting vendors, most of them carry manual and electric cutouts.
Old May 10, 2007 | 09:52 AM
wayfastwhitey's Avatar
That is as long as you have an aftermarket catback. You should make a sig with info about your car.
You are only going to need one cutout. Electric would be the way to go so you can open it with the flip of a switch and not have to crawl under the car every time to cap/uncap it as you would with a manual. Although electrics are more expensive than manuals.
Old May 10, 2007 | 12:00 PM
2000GTP's Avatar
Even on a stock exhaust, I used a 3" cutout, I just had the shop build up the welds. I personally haven't seen a cutout in the 2.75" sizing to fit the stock i-pipe.
Old May 11, 2007 | 12:31 PM
LT1FUN's Avatar
I second the idea of getting an electric cutout. I had a manual for a while and it sucks have to crawl around capping and uncapping. The electric just makes things so much easier.
Old May 11, 2007 | 03:30 PM
You are right. I thought I saw that QTP made 2.75" ones, but they are 2.25" and 2.5".
Old May 11, 2007 | 05:02 PM
why do people use two cutouts instead of just one, and also my exhaust guy said he didn't think there was room for a cutout, especially for two cutouts.
Noct
May 26, 2016 10:26 AM
95chwagon
Parts Wanted
Feb 28, 2015 12:12 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Nov 20, 2014 06:03 PM
