headers question? new guy
fixing to get pacesetter lts ... don't have any problem with emissions here and needed some help as far as knowing what to keep and how to bypass any emission that is not needed and what need to be keep .. do I need air.. egr.. what is all this don't know what these are and what they are the engine is out of the car and there are some pips on the manifold that run to the back of the engine ... do I need to get a tuner for this ??? help I'm new lol to this
You can get rid of the AIR and EGR if you desire. You will then want to get the "race" style headers that do not have those fittings. You will need to get a set of EGR blockoff plates which are easily found on Ebay and vacuum caps. You will have to have the AIR and EGR codes tuned out of the PCM. Also, since you will be using an ORY pipe, you will have to have the rear 02 sensor codes tuned out as well to avoid an SES light.
I remove all the things on the back of the intake and replace them with pulgs that are found on ebay around how do they run and also how much do the race pacesetter headers run for..and what is an ory is it a difficult thing to do or should I just leave the egr and get the headers that just require the remove of the exhaust manifolds .. imo I just want something that is quick and does require that much time consuming (for now) but I see it as if the engine is out I wanna do the headers now..
k I see what u mean ill just go with the emission stuff just without cats tho and as far as a ory I would put a cutout around where .... when u say u have to tune does
that mean u need to get a tuner like a hypertech?? or how do u go about doin a tune for the 96 camaro
The Hypertech is pretty much good for thermostat and rearend gear changes. For tuning like that, you will have to go to a speed shop that can tune an LT1 PCM. If there is not a shop local to you, consider doing a mail-order tune where the tuner sends you a tuned PCM and you send them back your original PCM as the core.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
