Header Leak HELP
Old Feb 17, 2007 | 10:38 PM
Alphawolf47's Avatar
Header Leak HELP
Hey guys, just need some advice. I have a set of BBK headers that are leaking terribly at the heads. When I originally did my header install I ended up having to use paper gaskets and they didn't take long to fail in a couple of major places. I bought a set or Mr. Gasket copper gaskets and installed them today and it seems like they don't fit or aren't seated properly. It seems like every cylinder is leaking slightly whereas with the paper gaskets I had a couple very pronounced leaks. I went back and made sure all of the bolts were torqued right and that the Y-Pipe was seated well and everything checked out fine. Any of you guys have this same experience? How did you fix it?
Old Feb 17, 2007 | 11:25 PM
ajlew9428's Avatar
try the percys multilayered dead soft aluminum gaskets. They work great
Old Feb 18, 2007 | 12:25 AM
Critter's Avatar
take them off and look for black spots theres where your leaks are. i used ultracopper on mine and no leaks at all. just don't go crazy with it and keep in on the gaskets you dont want to silicone to jack up your o2's
Old Feb 18, 2007 | 04:47 AM
2000GTP's Avatar
Did you make sure the surface of the head was clean before putting on the new gasket and re-installing the header?
Old Feb 27, 2007 | 12:39 PM
danhr's Avatar
check ebay. I have tried lots of different header gaskets... the percy's aluminum, hookers, the paper ones, no gasket at all...
by far the best ones were the cheap ebay ones I got. and they were half the price of the percy's too....
copper gaskets + breslin bolts = never worry about a blown header gasket again. period
Old Feb 28, 2007 | 11:03 PM
mrmint69's Avatar
The gasket set i purchased on Ebay are a different size opening than the Mid Pacesetters. The embossed gasket part would be almost inside the header opening so that would not seal but instead just sit there useless and not do what it should and only give me 1/16 of an inch in a few spots of seal. The opening on the copper gasket that came with the kit are 3/8" taller and fit perfect. I am sure there are tons of leaky gaskets out there with this problem. I am glad i checked first and sure hope others check the fitment before installing theres.
Old Mar 1, 2007 | 09:33 AM
OBE1 95Z28's Avatar
Breslin bolts are out of business.
Old Mar 1, 2007 | 09:37 AM
danhr's Avatar
damn.. that sucks... I'm glad I got my set and an extra 16 in case I lose any....
Old Mar 1, 2007 | 09:51 AM
danhr's Avatar
http://www.apo.com.au/store.html
that site still has them for sale.... at a horrible price
Old Mar 1, 2007 | 10:16 AM
2000GTP's Avatar
Ouch, those things better be made of gold, not stainless steel.
Old Mar 1, 2007 | 02:14 PM
danhr's Avatar
gold is soft, so the threads will strip easier...
these are made of diamonds baby
Old Mar 1, 2007 | 04:14 PM
2000GTP's Avatar
I'm still trying to figure out what justifies them costing nearly double what the competitors are asking.
Edit: I'm looking at the website, it is an Australian based company, maybe that is the reason?
Old Apr 23, 2007 | 08:10 PM
camarosource's Avatar
Where did you hear this? My engine builder says that is not true and they can still order from them without any problems.. what was the reason they "apparently" went out of business? The website also is running and there is no mention of this.
Old Apr 23, 2007 | 09:36 PM
OBE1 95Z28's Avatar
I read it here: http://web.camaross.com/forums/showt...hlight=breslin
Midnight_Z
Feb 16, 2016 09:36 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
