header install problem
Old Apr 27, 2007 | 09:56 PM
deputydough's Avatar
is there a secret to getting a long tube header in on the driverside. i have pulled the valve cover, disconnected the steering shaft, pulled plug and wires. it will not go. i have tried top and bottom. wtf. any suggestions? the passenger side dropped in no problem.
Old Apr 27, 2007 | 09:59 PM
gt_biker13's Avatar
I had to undo the drivers side engine mount and used a bar to tilt the engine up slightly, try and get someone to help you with that.
Old Apr 27, 2007 | 10:05 PM
i was hoping you would not say that. lol. may have to do that. thanks
Old Apr 28, 2007 | 11:22 AM
2000GTP's Avatar
The drivers side I was able to get in thru the bottom without a hitch. I had to have the car raised up pretty high though.
Old Apr 29, 2007 | 06:34 PM
Bayer-Z28's Avatar
FWIW, I had to remove my oil filter. Or have someone shove the tailshaft of the trans over with their feet to basically move the engine over enough to get it to slide in.
Old Apr 30, 2007 | 08:36 AM
shock6906's Avatar
I just installed my long tubes over the weekend so it's all fresh in my head. Here are some tips.
1. Remove the oil filter
2. Remove the spark plugs, they're easy to put back in on the driver's side even after the headers are in.
3. Disconnect the engine from the mount on the driver's side while leaving the passenger side connected. Get a jack and lift the motor slightly. Leaving the passenger side mount in will cause the engine to rise and tilt giving you much needed clearance.
4. Unbolt and remove the bracket for the motor mount. It's the main piece that's holding up your progress. VERY IMPORTANT, put the bracket back in place before you bolt the driver's side header in. There's no way to wiggle it around once it's bolted in. I found out the hard way and had to unbolt the header.
5. If that slip fit primary is touching the steering shaft, remember that your engine is still jacked up. I forgot and unnecessarily clearanced mine. (yes I do feel like a schmuck)
The biggest single issue I had on my install was that M'er F'ing oil dipstick tube. Took me ~ an hour getting it out and getting it back in. x eleventeen.
Noenav
Mar 1, 2019 07:38 AM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
