Header install HELP
Old Apr 10, 2007 | 04:35 PM
slicknick54's Avatar
Header install HELP
I can not fit my lt's headers in. I dont know. i removed the starter and alt and exhaust shield. The egr is hitting. also how do you disconnect the steering linkage? Please help.
Old Apr 10, 2007 | 04:38 PM
00ls100's Avatar
what kind of car do you have? what brand of headers do you have? need some more info to help you out
Old Apr 10, 2007 | 04:44 PM
97 z with lt pacesetter emission headers
Old Apr 10, 2007 | 04:45 PM
2000GTP's Avatar
I thought I read in one of your old posts that you had a 97. If that is the case, remove the passenger side valve cover and that should give you just enough clearance to snake that header in thru the top. As for the steering linkage, its a matter of removing the bolt and pulling it up and off.
Old Apr 10, 2007 | 04:49 PM
which bolt the one when i look straight down at, not in the closed case further down
Do i knock it off the bar then
Old Apr 10, 2007 | 05:04 PM
pattracing212's Avatar
honestly, i did it a different way that worked too. there are a number of ways to do it. i loosened up the motor mounts one side at a time and tilted the engine to fit the headers in. it was easy but i have never tried the other ways.
Old Apr 10, 2007 | 05:06 PM
2000GTP's Avatar
Sorry, I should have pluraled that. I took off both the top bolt and the bottom bolt and then slide the linkage off.
Old Apr 10, 2007 | 05:48 PM
removed valve cover. still hitting on lower a arm . starting to get pissed
Old Apr 10, 2007 | 05:52 PM
tilt the engine
Old Apr 10, 2007 | 06:02 PM
2000GTP's Avatar
I had to play around with the angles, it took awhile. The passenger side is a PITA.
Old Apr 11, 2007 | 12:12 AM
so what do i have to do to jack my motor up?
Old Apr 11, 2007 | 08:45 AM
2000GTP's Avatar
Unbolt a motor mount to tilt one side.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
