Header exhaust leak
Old Sep 3, 2008 | 08:14 PM
stvski80085's Avatar
Header exhaust leak
Couple questions. One is it hard to change the gasket on the exhaust side of the headers? Does a stock gasket work with headers or does it need to be something special? Thanks for any help. Trying to figure out where this knock sound is coming from.
Old Sep 4, 2008 | 02:40 PM
Andrew@MarylandSpeed's Avatar
When you say "on the exhaust side of the headers" are you talking about the collector (the outlet)?? Or are you talking about where the header bolts to the cylinder head?
To try to find a knock sound take a length of tubing, put one end up to your ear and the other end around the joints of your exhaust, and around the header flange. You'll hear where the knock is coming from when you find it, and you won't burn your face/ears
Old Sep 4, 2008 | 06:20 PM
Green96Z's Avatar
Is it a knock or a ticking? Usually a ticking sound is associated with leaking headers. You can use copper gaskets on headers, but I chose to go with Fel-Pro gaskets.
Old Sep 4, 2008 | 07:53 PM
JMG97SS's Avatar
Percys dead soft! My headers were used and the flanges looked iffy and they sealed up. Got them at AutoZone.
Old Sep 5, 2008 | 07:53 AM
2000GTP's Avatar
I used Fel-Pros sprayed with a copper adhesive. Never had a leak. Also, did you verify that you didn't have any loose exhaust bolts?
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
