header choice
Old Apr 14, 2007 | 11:20 AM
joshuas93lt-1's Avatar
Question header choice
im going with the longtube pacesetters for my set-up question is if i can still use my a/c and all my emissions with this system and how hard will it be to change spark plugs in future with this type or shall i go with mids. Anyone know of any other brand that are user friendly and with a good feedback i mean there are lots of brands out there. My system consist of ported heads, hot cam, 1.6rr, cold air ind., 3" flowmaster exh.,hypertech chip, 160deg. therm.,msd box,msd spark wires 8.5, a/c delco plugs. My next project would be installing a 52 or 58mm throttle body. your feedback would be truly helpful here thanks.
Old Apr 14, 2007 | 01:28 PM
mrmint69's Avatar
The mids are emission compliant and easy to install. Make sure you protect the coated ones real good. I got some scratches on mine during the install. Hope they don't rust right away
Old Apr 14, 2007 | 01:54 PM
2000GTP's Avatar
With long tubes, spark plug access will be amazing, and much better compared to some other header styles. You can also get the headers with the emissions fittings so you can keep the AIR and EGR systems intact. And yes, you can still use the A/C system.
Old Apr 14, 2007 | 02:52 PM
Talking headers
thanks alot gents., you guys made my day, now it's just choosing a brand. I was thinking pacesetter longtubes ceramic what's everyones favorite and negative experience with there longtube brands.
Old Apr 14, 2007 | 04:17 PM
CamaroRacing12's Avatar
where is a good place to order pacesetter longtubes cheap??
Old Apr 14, 2007 | 04:39 PM
beeker82's Avatar
byunspeed.com
Old Apr 14, 2007 | 06:29 PM
2000GTP's Avatar
They are a decent header, but it is a budget header and you pay for what you get. My coated Pacesetters started rusting in less then a years time and my car never sees rain or snow. Other then that, the power gains are good, ground clearance is good, and spark plug access is much improved over stock manifolds.
Old Apr 16, 2007 | 05:44 PM
FAST96Z's Avatar
http://customssi.com/cart/index.php?...th=1_6_176_352
heres where i got mine scroll down a bit
Old Apr 16, 2007 | 06:01 PM
SuperSport88's Avatar
fast96z, its says coated but they are the painted black ones. By coated do they mean black or the actual ceramic coating, because if its ceramic thats a hell of a deal.
Old Apr 17, 2007 | 08:24 AM
2000GTP's Avatar
Those are coated, the painted ones usually run in the upper 200 range.
Old Apr 17, 2007 | 11:16 AM
Antz97ZNJ's Avatar
plugs changes suck on a LT1 regradless. Go w/ the LT's
Old Apr 17, 2007 | 09:24 PM
FAST96Z's Avatar
thay are the ceramic coated have mine right here ready to install this weekend very good deal
Apr 3, 2015 10:54 AM
transam_388
Mar 15, 2015 11:53 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
