Header bolts popped out at Open throttle, asap what bolts do I need for Pacesetter LT
Old Nov 11, 2011 | 04:35 PM
thewhite97z28's Avatar
My friend and I used mustang header bolts and after 800 miles of driving two popped out on the highway at open throttle and the engine light was blinking?????? I drove home and it ran a little funny loud ticking. Engine light wont flash anymore thank god but what bolts are good at a parts store for the pacesetter Long tubes for the 1997 Camaro?? Can I use stock ones from advance auto or autozone???
These good? http://shop.advanceautoparts.com/web...|GRP2023P_____
Old Nov 11, 2011 | 06:17 PM
bw_hunter's Avatar
Re: Header bolts popped out at Open throttle, asap what bolts do I need for Pacesette
3/8-16 3/4 or 1" long. By both...try the 1" first. I use 3/4"longwitm my long tube but once a bolt pops out you may have so damaged threads.
Old Nov 11, 2011 | 07:37 PM
Any kind of sealant on the bolts? My friend did the headers since we were in a rush and the wife wanted the car out. I am selling the car so that's why I'm in a rush.
Old Nov 11, 2011 | 07:40 PM
bw_hunter's Avatar
No sealant but do use anti sieze compound....
Old Nov 11, 2011 | 07:43 PM
Kurt Crosbie's Avatar
How easy is it to damage the valvetrain running with the header bolts out?
Sent from my SCH-I405 using Tapatalk
Old Nov 11, 2011 | 07:46 PM
bw_hunter's Avatar
Not sure it's any easier than with the exhaust intact. The noise you hear is probably a bad exhaust gasket......be sure to change that as well.
Old Nov 11, 2011 | 11:36 PM
vangill's Avatar
with pacesetters run the inch ones. go to oreillys and get the mr gasket ones, they r like 7 bucks
Old Nov 12, 2011 | 12:20 AM
97WS6SCharged's Avatar
3/8 -16 x 1" is the way to go. Put a little teflon tape on them and they won't back out but make sure you heat cycle them a few times and retighten them. I always keep a 7/16" ignition wrench in the center console so I can snug mine down from time to time.
Old Nov 12, 2011 | 11:16 AM
These claim they never pop out again. Going to get them in an hour.
http://www.autozone.com/autozone/acc...er=723229_0_0_
That ticking noise was the header gasket since the driver side header was loose!
Old Jun 6, 2012 | 07:31 PM
KSSS's Avatar
Anyone else try these.... Spectre/3/8 in. - 16 x 1 in. lockwire header bolt with 12 pcs. bolts, 6 pcs. lock wires and tool (4668) | Exhaust Header Bolts | AutoZone.com
Old Jun 6, 2012 | 08:59 PM
pgerst's Avatar
Those look cool. I used wire-lockable cap screws from mcmaster carr; do not have any way to use a wrench, only allen, so a few of them were quite a bee-atch to get on. I am going to order a set for the next time I take the headers off.
Old Jun 9, 2012 | 08:54 PM
CamaroBoy96Z28's Avatar
I run ARP 1" underhead length since 03. No issues. Check them after the first 2 weeks and re-tighten since they've been through some heat cycles.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Jul 4, 2005 05:00 PM
