Flat (rectangular) Side Exit Exhaust Tips?! ---
Old Dec 11, 2006 | 06:04 PM
AlwaysCode390's Avatar
Question Flat (rectangular) Side Exit Exhaust Tips?! ---
I want to have a custom exhaust built and have it exit BEFORE the rear wheels on the sides. I dont think anything will clear all the bumps, but a flat style tip (rectangular). Anyone know where to get some? Would the stock ones from the rear be flat enough? THANKS ---
Old Dec 11, 2006 | 06:19 PM
Brangeta's Avatar
I recently saw a Camaro with that, but I wouldn't recommend it. The owner said it caused him to bottom out on just about everything. And by the looks of it, there was only about 2 or 3 inches of ground clearance underneath it.
I suppose if you have big wheels on it and haven't lowered the car, it might be ok though.
Old Dec 11, 2006 | 06:23 PM
reamo04's Avatar
what size exhaust are you running? i think the stock tips are 2.5", but not entirely sure
Old Dec 12, 2006 | 06:35 AM
teke184's Avatar
stock tips are either 2.5 or 2.25"...
but i agree...it's not just the tips that would cause clearance issues, its the pipes leading to them. the outer edge of the unibody just doesn't have the clearance for such a setup.
true duals and dump it
Old Dec 12, 2006 | 11:00 AM
I was going true duals, but dumping it wont pass inspection ( learned that with my 67 ). They force you to have it on the sides or in the rear.....and the shop I am dealing with told me if I want it out the rear it will "clang" on the rearend/body. Hmmm what to do . BTW 2.5" ---
Old Dec 12, 2006 | 03:47 PM
ABA383's Avatar
A local shop here does 3" and can go all the way over the axle on either both sides or both on the passenger side...It can be done and can be done right with no contact going out either side with 3", so 2.5" is doable, too...
--Alan
Old Dec 12, 2006 | 05:30 PM
CamaroRacing12's Avatar
--Alan
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ expensive tho lol
Dump em and go to another inspector....one more laxed and will get on his back to get under the car..... look for a foreign guy....they usually dont care..
Old Dec 12, 2006 | 07:06 PM
teke184's Avatar
have em set up to go out the side...with a 3bolt flange...after inspection...bolt up a set of turndowns
Old Dec 12, 2006 | 07:32 PM
good suggestion
Old Dec 13, 2006 | 03:03 PM
Exclamation
Thats a GOOD idea!!! Thanks ---
Old Dec 13, 2006 | 07:29 PM
teke184's Avatar
yeah....sometimes i even amaze myself
Old Feb 20, 2007 | 08:52 PM
duals's Avatar
try Dr Gas on Google they are spendy but can be down to 1" tall
Old Feb 21, 2007 | 06:11 PM
Greed4Speed's Avatar
There are aftermarket tips just like the rectangular Z28 tips.
I agree w/Teke's idea. You should be able to even get some pipes under the axel and out the back pretty cheap too. Bolt them on for inspection or road trips and leave them off when you want.
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 08:12 PM
PaulN64
Aug 8, 2002 05:39 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
