Exhaust Manifold gaskets
Old Mar 6, 2007 | 08:29 PM
97ss497's Avatar
I'm installing Mac's on my girlfriends 99z and need the part number's for GM's exhaust manifold gaskets (to head) and 3 smaller gaskets for emissions hook up. I want to purchase on GMPartsdirect.com. The local GM dealer is closed so I can't call and ask. Is there a link to common part numbers for an LS1 on this site anywhere?
Thanks in advance.
Old Mar 6, 2007 | 09:07 PM
Bayer-Z28's Avatar
12558573 Exhaust manifold gasket
I like the metal gaskets the best. I believe that's what they are.
Old Mar 7, 2007 | 01:23 PM
NJ-LE's Avatar
Question
Not to hi-jack the thread but when installing embossed metal exhaust gaskets does the raised part go toward the head or the header flange?
Old Mar 7, 2007 | 03:10 PM
Bayer-Z28's Avatar
^they should be labeled. "head side" or "Manifold side"
Old Mar 7, 2007 | 04:52 PM
NJ-LE's Avatar
Exclamation
There's never a shortage of "wise guys"... If the gaskets had been marked I wouldn't be asking.
Old Mar 7, 2007 | 06:01 PM
Greed4Speed's Avatar
If the original gaskets aren't messed up, then you can reuse them. I did and after being daily driven with headers for over 2 years I still don't have any leaks.
Old Mar 7, 2007 | 08:33 PM
soontobeGN's Avatar
Raised side goes outward
Old Mar 8, 2007 | 11:33 AM
NJ-LE's Avatar
Smile
Thanks for the answer soontobeGN ... best of luck!
Old Mar 8, 2007 | 12:28 PM
soontobeGN's Avatar
no prob, let me know if you run into any other problems, I think I had every problem possible when I had my LT1 with long tubes
69z-28
Jan 29, 2016 10:46 PM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
