Exhaust leak....anyone recommend (tape, putty, ect?) ---
Old May 24, 2007 | 05:08 PM
AlwaysCode390's Avatar
Question Exhaust leak....anyone recommend (tape, putty, ect?) ---
The guy before me had the y pipe to catback clamp welded shut (but just from the bottom), and I think the gasket is blown to peices so its leaking from the top ( near the floorboard) . I am about to swap out y pipes, so for a quick fix can I use a putty or a type of exhaust "tape" to get the sound to quiet down for now? I know I can go to the mechanics and get them to cut it and fix it correctly but that is money/time waisted on parts I wont have soon. THANKS ---
Old May 26, 2007 | 04:07 AM
Ratlor's Avatar
You can try JB weld or copper gasket maker. That might do the trick. I'm not positive on how well either of those will work that close to the block, where the heat is highest. But the copper gasket maker is made for pretty high temps I believe. So it's worth a shot, especially if it's only temporary!
Old May 26, 2007 | 08:24 AM
ws6transam's Avatar
ouch. JB Weld fails when temperatures go above 300 degrees so that wont work. Copper gasket maker, though good to 600 degrees, wont hold up to the pressure and will just blow off.
Your best bet is probably to enlist the help of a mechanic and use a cutoff wheel to grind out that weld. Then you can separate the pipes and replace the gasket.
Old May 26, 2007 | 10:43 AM
Thank you guys very much ... I hate getting someone elses rigged "junk" ---
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Brake_L8
Jan 20, 2015 09:44 AM
Queens94z28
Nov 20, 2014 06:03 PM
Brady
Jul 29, 2002 10:30 PM
