Exhaust Leak
Old May 9, 2007 | 05:33 PM
SFB767's Avatar
Question Exhaust Leak
Recently my car has developed a sound underneath it and I believe it has an exhaust leak somewhere near the y-pipe.
How do you go about pinpointing it and fixing it permanently?
Thanks.
Old May 9, 2007 | 05:35 PM
2000GTP's Avatar
How do you have your y-pipe secured to the headers, clamps? If so, an easy start would be to run over the bolts with a ratchet and make sure the clamps are completely tight.
Old May 9, 2007 | 06:29 PM
SSpdDmon's Avatar
Usually, there'll be a bit of black exhaust soot near any leaks. The other thing you can do is safe raise the car, start it up in Park w/ e-brake, and slide underneath. Run your hand along the tubing carefully about a 1/2 inch off the pipe. If there's a leak, you'll feel it....like someone's blowing on your hand.
Old May 10, 2007 | 10:20 AM
Greed4Speed's Avatar
Run some seafoam and look for the smoke.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
