Catback removal question
Old Jan 13, 2008 | 11:19 PM
Green96Z's Avatar
Ok, just put in my LTs, and with the y-pipe my LM catback doesn't line up. It ends up hitting the driveshaft. It's not welded, so I can adjust it. Problem is, all the pipes are stuck together and not wanting to come undone. What's the best way to get these things apart? And what about getting it back together? Should I use a pipe expander on the crimp parts? Thanks in advance.
Old Jan 14, 2008 | 12:06 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Sounds like your install is hitting some speed bumps. Fortunately, I was installing a new catback when I did my headers, so I was able to just cut the old exhaust system off without worrying about leaving it in a reusable condition. The GMMG mated up perfectly with the Kooks Y-Pipe. I really had no idea how that was going to work out beforehand.
Old Jan 14, 2008 | 12:24 PM
Kaj's Avatar
Kaj
I had to have an exhaust shop fab a small offset piece from the bullet to my y-pipe.
Old Jan 14, 2008 | 02:19 PM
Green96Z's Avatar
Kooks told me to use some WD-40 and a dead blow hammer to get the pipes loose. The only pipe I really need to adjust is the elbow from the resonator to the over axle pipe. It just needs to slide up, then I should be good. Hopefully I'll have Friday off of work so I can get this thing done.
Old Jan 14, 2008 | 05:07 PM
Kaj's Avatar
Kaj
yeah, the over-axle piece is kinda crummy. I had to actually bend it a little up to make the connection.
Moshbmx1
Feb 17, 2015 10:51 AM
sscott
Jan 17, 2015 04:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
