Pics of TD clearance
Old Dec 26, 2007 | 06:15 PM
mdacton's Avatar
I have done alot of searching, I went from an edlebrock T304 muffler(3 5/8" thick) to Bullets ( I ran previously) and the clearance is really bad with the bullets and they are touching the floor on the bottom.
It works fine and just a drag car...but looks horrible from the side, any other options? I would like to see some other set ups of 4th gens with pipes dumped at the axle
Old Dec 26, 2007 | 07:25 PM
ABA383's Avatar
Here's my 3" TDs with an X with the Edelbrocks...These are older pix of when it was dumped...Now its a side exit system...I don't have pix of it, but its pretty damn cool without looking rednecky...
https://www.camaroz28.com/forums/sho...d.php?t=493863
--Alan
Old Dec 26, 2007 | 08:32 PM
mdacton's Avatar
Nioce how you ran yours, My tq arm mount is straight across, I may just put my 304's on like I had it or put the bullets right off the headers.
Thanks alan, don't know why I couldnt find that. Good luck to you next season
Old Dec 26, 2007 | 11:43 PM
MulletRacerLT1's Avatar
I would like to do something like that.But for now im just running long tubes into purple hornies
Old Dec 26, 2007 | 11:47 PM
ABA383's Avatar
Thanks...I had the straight across TA mount and switched it for the one with the dip for the TDs...I've got the new built trans in, converter restalled to 4000 from 3600, a 6 point going in, and a Spohn drag rear sway bar going in...I'm hoping for a 10.99999 pass...
--Alan
Old Dec 27, 2007 | 02:08 AM
romoranger's Avatar
that there is a picture of mine. They hang low because I ran them under the bar my torque arm is attached too.
http://i5.photobucket.com/albums/y18...P1010127-1.jpg
Old Dec 27, 2007 | 01:36 PM
Bersaglieri's Avatar
I have the same dilema. I have the BMR Track Pack and it has the TQ Arm mount bar that welds to the sub frames. I am selling my GMMG to run duals and I think I'm going to have a rough time with finding a good setup.
-Dustin-
Old Dec 27, 2007 | 01:52 PM
romoranger's Avatar
you either have to dump it before the subframes, or you can run the x-pipe right on top of the hump in the trac-pak. My problem was that my driveshaft loop is not connected to my torque arm, it is bolted underneath the car where that flimsy piece of metal was, and my torque arm cross bar has a hump that is not inline with it. I had no choice but to go underneath.
There is one guy on the board that actually cut the floor board and raised it, then ran his exhaust pipe over the bar. It came out really sweet and is something i might do if i can get over hacking my floor.
Old Jan 7, 2008 | 08:31 PM
white97T/A's Avatar
--Alan
That is awesome !!! It is exactly what I had in mind that I would like to do with my exhaust when I have the $$ to upgrade to Kooks. I have never seen it done before in stainless.. Thanks for the inspiration. Btw do you have a list of the parts that you collected to make this a reality?
(sorry for the hijack)
Old Jan 8, 2008 | 03:13 PM
ABA383's Avatar
Thanks! I had it done by a great fab shop in my area and we did it in stages...I think the dumped set up required 4-5 3" stainless U bends with 5" radius and a small section of straight 3" stainless...The side exit required 3 more U bends...We used stainless V band clamps for the transition from headers to exhaust, good quality hangers, and 2 Edelbrock stainless SDT 304s...The shop doesn't have a mandrel bender so he tigs pieces together to form what he needs...He's also doing my custom chrome moly 6 point roll bar with swings outs in February...
--Alan
Old Jan 15, 2008 | 08:20 PM
Bayer-Z28's Avatar
Here's a good TD FAQ thread on LS1Tech.. LOTS of pics..
http://www.ls1tech.com/forums/showthread.php?t=531756
Fastbird93
Apr 9, 2016 07:01 PM
Fastbird93
Jul 11, 2015 04:37 PM
cmsmith
Jul 10, 2015 07:19 PM
colts0455
Jul 8, 2015 12:21 AM
cmsmith
Jul 5, 2015 07:23 PM
