Cat back question
Old Mar 20, 2007 | 12:53 PM
Black6spdZ's Avatar
Cat back question
i have a magnaflow cat back on my car now and was curious as to how restrictive it actually is with my set up? The dyno #s are from when i had 2.5" true duals with an x-pipe. I have not dynoed with this catback on, however i was wondering if it would be beneficial to put on cut outs?
Old Mar 20, 2007 | 01:51 PM
MARKTHOMASBRAND's Avatar
A cut-out would probably release about another 10hp
Old Mar 20, 2007 | 02:36 PM
2000GTP's Avatar
The Magnaflow is a very good flowing catback so I'm sure its not choking up your setup too badly. I have a cutout on my Magnaflow as well, but its mainly for added noise. I doubt by having it open, I'm gaining a full 10hp, but I'm sure there is a few extra ponies being had.
Old Mar 20, 2007 | 04:52 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Do Magnaflow catbacks flow better than Flowmaster? The only comparisons I've ever seen did not include the Magnaflow.
Old Mar 20, 2007 | 04:54 PM
BTC's Avatar
BTC
And completely off topic, I used to live in Atlanta and bought my current daily driver, a 2001 Jeep Grand Cherokee, at Nalley Jeep.
Old Mar 20, 2007 | 05:21 PM
2000GTP's Avatar
I'm pretty sure the Magnaflow is going to have the upper hand. There is alot mentioned of the Flowmaster being poor in terms of flow.
Old Jul 16, 2008 | 01:42 PM
smokintires's Avatar
does anyone know where i can find this article im am really interested in to see how everyone did.
Old Jul 16, 2008 | 04:28 PM
slomarao's Avatar
flowmaster flows very bad. Pretty much any exhaust company can produce something better than them
Old Jul 18, 2008 | 11:25 AM
how can you beat something that has no baffles and no chambers just striaght through.. cant beat that!
Old Jul 18, 2008 | 05:35 PM
Hard to believe that a 3" catback is going to provide adequate breathing to a 383 that is capable of making 457rwHP. Its got to be costing you HP. If you want a catback, and not duals, look at a 3.5" or 4" Mufflex. They will support huge HP. I saw the 4" with the single in/single out Flowmaster make 1,125 flywheelHP. Taking the 4" Mufflex/Flowmaster off, and running Borla XR1's on the collectors did not produce any HP increase - verified on a chassis dyno... just a 50# weight reduction.
Its sort of pointless to make a gneeral statement like "flowmaster flows bad".... they make a huge range of mufflers, and many of them flow very well. Sure... some comparison test run 15 years ago by a magazine on a low-end Flowmaster did not produce impressive numbers.... but that's a single data point.
Old Jul 30, 2008 | 08:27 PM
mzgp5x's Avatar
I thought my 3 1/2" Mufflex would support a 383 - D1, but, I was wrong. I selected a Spintech muffler, but, was running a dual cat Random 2 1/2" cat system. After much work re_working the blower suction and pressure side indiction system, I actually blew the cat elements into the exhaust pipe. I have since cut the converters out and installed straight pipe (I also had a QTP cut-out after the cats as well). I found that the Spintech 3 1/2 chambered muffer was flowing alot more. Well, it was alot of noise and resonated very bad @ 2K rpm. I installed a CarChem 3_plate insert after the Qtp cut-out. That helped alot. That's where I'm at. The best way to learn is on your own. I had to re-yune the fuel map and engine dur to the change in exhaust flow. I still run the open 3 1/2 QTP when I need to. B
rockync7
Jan 1, 2015 05:10 AM
Jul 4, 2005 05:00 PM
tubby
Oct 13, 2003 09:16 AM
kurob25
Aug 5, 2002 08:03 PM
squirrels
Jul 13, 2002 01:58 AM
