Bought DMH cutouts, ran a gasket or not?
Old Oct 9, 2009 | 09:20 PM
onefastmx5's Avatar
Do you guys running these cutouts putting the cheap paper gasket behind them, maybe silicone, or nothing? With my manual caps, the paper gaskets are starting to leak. I thought about bolting them straight to the cutout with some copper gasket sealer, but I don't know. Not in the instructions
Old Oct 10, 2009 | 08:44 AM
onefastmx5's Avatar
Got all the wiring ran and going to install today if work is slow, anyone want to chime in?
Thanks,
James
Old Oct 10, 2009 | 08:16 PM
onefastmx5's Avatar
Used red High temp rtv with no gasket. No leaks so far. These e-cutouts are badass!
Old Oct 30, 2009 | 12:26 AM
Moshbmx1's Avatar
A little late on the reply but I just ran the gasket that came with the cutout. I havent had any leaks so far. The only problem I have is mating the flowtech to the s pipe. I have some reengineering to do next spring on it. Put the cutout in place of the cat and did it quickly so I have a 3 inch run or so of small pipe between the flowtech and s pipe that rattles and wont seal tight Have a new s pipe ready to go in though to remedy the problem.
Magenta_Hearts
Mar 25, 2015 10:24 AM
95chwagon
Feb 28, 2015 12:02 PM
Queens94z28
Dec 20, 2014 09:11 PM
stanghunter211
Aug 29, 2002 03:04 AM
