ARP 1'' Header Bolts?
Old Jan 6, 2007 | 12:14 PM
StephenDeli22's Avatar
Whats the part number and where can I find them?
Old Jan 6, 2007 | 12:58 PM
LT1 POWR's Avatar
Summit part # ARP-400-1212.
I believe these are what I have.
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 6, 2007 | 01:06 PM
Any reason why you went 12 point over 6?
Old Jan 6, 2007 | 03:17 PM
Projectz28's Avatar
Moderator
I have them also. 12pts because you can grind down 3/8" box wrench and still put it around the entire head of the bolt. I've use those exact bolts for several year now and many header removals and never had a problem. I just put them back in my new motor.
Old Jan 6, 2007 | 05:10 PM
BassProCamaro97's Avatar
If I were to do it again I would get the Breslin bolts. They have a a spot in the head of the bolts for an allen wrench. Anything that gives you another option for tightening those bolts is like gold in these engines. Just a thought.
~Jim~
Old Jan 7, 2007 | 02:24 AM
LT1 POWR's Avatar
Gives you more angles to work with, you really need it in an LT1 engine bay.
Old Jan 9, 2007 | 03:30 AM
seawolf06's Avatar
The 1" bolts won't bottom out?
Old Jan 9, 2007 | 03:49 AM
95LT1conv's Avatar
http://www.jegs.com/webapp/wcs/store...44888_-1_11539no 1" will work fine. i used the ARP stainless with the 5/16 head. also instead of using the washers supplied with the bolts i bought a package of Mr.Gasket header lock washers
--it is part # 070-400-1110 that i used
Old Jan 9, 2007 | 03:57 AM
seawolf06's Avatar
But what about the part number 070-400-1210?
Those have the 5/16" head, 1" length and 12 point head, and it's cheaper, wouldn't that be the best combination?
Old Jan 9, 2007 | 04:06 AM
95LT1conv's Avatar
those would work fine too. i just posted what i used. i didnt like the fact that i would HAVE to use a 12 point. i like options
Old Jan 9, 2007 | 07:36 AM
SnakeOiler's Avatar
any reason you guys are buying 16 piece kits vs. the 12 piece kit? Do you all have big block heads?
Old Jan 9, 2007 | 07:43 AM
seawolf06's Avatar
The bbc kit I posted is cheaper, maybe that's a reason. Then you also have some extras just in case.
Old Jan 9, 2007 | 07:02 PM
Projectz28's Avatar
Moderator
yeah the only reason is price. I have actually bough this same set several times for a few friend who I have put headers on for. Now I hav an extra set of 12
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
