ARP 1'' Header Bolts?
Summit part # ARP-400-1212.
I believe these are what I have.
http://store.summitracing.com/partde...5&autoview=sku
I have them also. 12pts because you can grind down 3/8" box wrench and still put it around the entire head of the bolt. I've use those exact bolts for several year now and many header removals and never had a problem. I just put them back in my new motor.
If I were to do it again I would get the Breslin bolts. They have a a spot in the head of the bolts for an allen wrench. Anything that gives you another option for tightening those bolts is like gold in these engines. Just a thought.
~Jim~
~Jim~
http://www.jegs.com/webapp/wcs/store...44888_-1_11539no 1" will work fine. i used the ARP stainless with the 5/16 head. also instead of using the washers supplied with the bolts i bought a package of Mr.Gasket header lock washers
--it is part # 070-400-1110 that i used
SavageZ28
17
Jul 14, 2002 11:04 PM
