Anyone running True Duals, exiting behind the doors, before the wheel?
its not hard...just run some 90* bends instead of turndowns.
just realize you'll have about 2" of ground clearance. and probably a bad headache from the drone.
something else i've heard...but can't substantiate...is the negative affects on the wheels and rims. seems i heard that Ford was recalling some trucks that had the exhaust ending just ahead of the wheels because the exhaust fumes were deteriorating the steel rims over time.
i say do turndowns (looks sexy from behind) or go out the back.
I had mine running like that for a long time. Only issue I ever really had was ground clearance from the exhaust. The drone goes away as long as you get the exhaust out from under the car and don't dump it underneath.
