Air Tube Block Offs
get the tubes that originally went to your exhaust manifolds. get ahold of the flange that went directly to the exhaust manifold. cut the tube off. get your hands on a welder, and weld the hole shut.
z275plus:
If they use the same size and pitch as my 95 then try this outfit. Some member in the forum (can't recall who) suggested ...
http://www.cgenterprises.com/drain_plugs_metric.htm ... I got 3 plugs and gaskets mailed to my door for less than 1 blister-packed plug at the local auto parts.
I used:
#1016 22MM-1.5 Hex size=19 Thread length=12.5
#2508 22mm copper gasket
toll free phone orders too: 1-(800)-565-9743
I used:
Your 93 is different than all other years. The AIR for the passenger side manifold is integrated with the EGR system. That's not the case for 94-97, where AIR and EGR are two seperate ystems, and require different blanking plates for the EGR and plugs for the AIR,
99TransAmWS6
Feb 3, 2015 08:27 AM
95chwagon
Jan 13, 2015 09:19 PM
