Air Tube Block Offs
Old Mar 23, 2008 | 01:09 PM
z275plus's Avatar
Unhappy Air Tube Block Offs
What can I use to block off the Air tubes on my pacesetter mid tube headers ?
Old Mar 23, 2008 | 10:37 PM
On what year car/engine?
'Signature' ? ? ? ? ? ? ? ? ?
Old Mar 23, 2008 | 10:51 PM
danhr's Avatar
get the tubes that originally went to your exhaust manifolds. get ahold of the flange that went directly to the exhaust manifold. cut the tube off. get your hands on a welder, and weld the hole shut.
Old Mar 24, 2008 | 05:30 PM
z275plus's Avatar
Sorry about that, this is for a 95z, LT1.
Old Mar 25, 2008 | 07:28 AM
NJ-LE's Avatar
Smile
z275plus:
If they use the same size and pitch as my 95 then try this outfit. Some member in the forum (can't recall who) suggested ...
http://www.cgenterprises.com/drain_plugs_metric.htm ... I got 3 plugs and gaskets mailed to my door for less than 1 blister-packed plug at the local auto parts.
I used:
#1016 22MM-1.5 Hex size=19 Thread length=12.5
#2508 22mm copper gasket
toll free phone orders too: 1-(800)-565-9743
Old Mar 25, 2008 | 10:22 AM
Those are OK for 99% of the 95's. The dual-cat "CA emissions" A4 cars have the smaller threads used on the 96/97 cars. Check before you buy.
Old Mar 25, 2008 | 11:26 AM
Me>you's Avatar
You can make them yourself from sheetmetal, and gasket material...Done it 3 or so times for some lads down here
Old Mar 25, 2008 | 05:39 PM
How do plug a 3/4" deep female threaded hole with sheet metal? I can see how that would work for the EGR holes, but its difficult to picture it on the AIR connections.
Old Mar 26, 2008 | 12:07 AM
Kaj's Avatar
Kaj
was wondering the same thing myself...
Old Mar 26, 2008 | 12:11 AM
danhr's Avatar
was probably thinking of either the egr or the ls1 air fittings
Old Mar 26, 2008 | 12:31 AM
Me>you's Avatar
Yes, i was talking about the far superior LS1 motor
Old Mar 26, 2008 | 05:02 AM
2000GTP's Avatar
Nice response, and very helpful info you provided considering the original poster has a 95.
Old Mar 28, 2008 | 08:48 AM
SNOTGREEN's Avatar
R&D Speed, supporting vendor on here, sold me mine for under $20. Look nice too!
Old Mar 28, 2008 | 04:07 PM
Your 93 is different than all other years. The AIR for the passenger side manifold is integrated with the EGR system. That's not the case for 94-97, where AIR and EGR are two seperate ystems, and require different blanking plates for the EGR and plugs for the AIR,
alphaauto
Jan 23, 2015 07:42 AM
95chwagon
Jan 13, 2015 09:19 PM
jocamino
Dec 29, 2014 10:15 PM
Catmaigne
Dec 25, 2014 12:16 PM
