95 Lt1 longtube headers please help
is there anyway that i can weld the egr fitting on my pacesetter long tube headers i just want to plug the hole up or do they sell block off plates. I cant get the tube to connect to it and i just give up on it the tranx dip stick is in the way and that hole has a really bad exhaust leak my headers are banging on my driver side when i step on the gas any help please
Header install
Making a block off plate would be pretty easy, but I have read on this forum that htey sell them on ebay.
I had alot of trouble with my EGR hook up when I installed my pacesetters. I had to bend the EGR fitting slightly to get the header in the car, so that caused big problems for me when I went to hook it up. After fighting with it and the tranny dipstick for a while I ended up taking the EGR hose off at the back of the intake. This allowed me to straiten the header side of the hose out, I had tweaked it pretty good wresting with it. It never would have gone on like that. I still had to bend the tranny tube a bit, but it was alot easier to get on this way. Hope this helps.
headers
to heat it up do i have to take the header out or can i do that with the header on in the car man i sure in the hell dont want to take that damn thing off again lol. i have a really bad leak on the driver side which i dont under stand it sounds like its comeing from the y pipe where i have the clamps i used the compressor to bolt that clamp on is it better to weld in the ypipe or use clamps? also the driver side is banging on the top of my car rattleing around any help would be appreciated i cant stand the sound of the leaks the headers bolted on fine all the bolts are tight i don't think its them causeing the leak i know that damn egr fitting is leaking i gave up and didnt evan put a bolt in it the tube is connected but no bolt i hear the leak more on the driver side.
I will sell you a block off plate and gasket for the header, $2 shipped? It came with the block off plate set I bought but my headers are race only so I didn't use it.
As for the banging on the floorboard, I just did mine a week or so ago, haven't gotten around to fixing that yet. I've searched and seen some suggestions like heat up the header and y pipe and bend that section down, shim the tranny mount with washers so it's a bit lower and the engine angles the pipe away from the floorboard, remove the y-pipe and cut the bump in the frame, and seal up the hole with a custom piece of sheet metal welded there, I've even heard of welding a valve spring on the pipe or frame right there. Not sure what I'm going to do, but someone said that shimming the tranny might be bad, so be careful on that one.
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
