1 5/8 inch band clamp?
Old Jan 28, 2007 | 11:47 PM
archangelus2's Avatar
Question 1 5/8 inch band clamp?
I have MAC mid length headers on my 94 Z28 and a lot of people say they have used band clamps on the slip-tube to fix the leak that tends to develop there. My question is if the primary is in the vicinity of 1 5/8 inch what size band clamp did you use? I have looked all over the internet after a trip to NAPA where they only had a 2" band clamp available and I have still not found nothing smaller. Will a 2" band clamp work or should I keep looking?
Any other suggestions other than welding it?
Thanks.
-Gabriel
Old Jan 29, 2007 | 08:49 AM
NJ-LE's Avatar
Smile
The female tube is ~1.75". I found Summit has the following clamp:
SME-240175 $ 4.95 T-bolt clamps 1.5 - 1.8"
I would replace the Nylok nut with a stainless nut and lockwasher from any of the homecenters.
Old Jan 29, 2007 | 11:20 AM
Exclamation
I was specifically looking to avoid the t-style clamp as that is what comes with the MAC mids and is the source of my problem. Yet I have seen several threads with people claiming they have used band clamps but no one mentions the size?
Old Jan 29, 2007 | 01:00 PM
NJ-LE's Avatar
Smile
No T-clamp clamp was provided for the #1 cylinder tube on my set. The aftermarket vendor said to use the old U-clamp style. Clamp that down tightly and good luck if you ever need to pull that pipe! A T-clamp worked for me.
If the fit on yours is too loose then I suggest careful use of a pipe expander on the male tube to get closer to an interference fit along with the usual suggestion of a thin coating of High-Temp Silicone sealant. I know the exhaust heat there is too high but apparently the silicone "chars" up and helps.
Old Feb 2, 2007 | 04:36 PM
94blackz14.2's Avatar
Don't know if your headers are coated or not but I had mine welded and it only cost $10 at a local welding shop. That did the trick. While they were at it I had them get rid of the air tubes on the #1 & 2 primarys.
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
